fuel system
Old Oct 17, 2003 | 01:54 AM
frostie's Avatar
fuel system
A friend bought an 03 about 3 months ago. It currently has 10,000 miles on it. He did his second service last night. When he went to change his fuel filter it had no fuel in the bowl. The bowl is on the pressure side of the fuel pump, if Im not mistaken. We are both diesel mechanics and work on the big rigs. If there is an empty fuel filter than there is a fuel problem. My question is, has anyone changed there fuel filter and found the bowl empty or full.
We also believe he has a power problem. We should check fuel pressure. I suppose we will have to order new banjo fittings from Rod to check pressures.
If no one responds to this, than I will continue to kick his a$$ on the hills in my 92 Dodge CTD I would like to help him but I sure enjoy blowing his doors off with my 92
Old Oct 17, 2003 | 04:15 AM
Goodys1ton's Avatar
Re:fuel system
I just changed my fuel filter for the first time yesterday, 12,000 miles, and the bowl was full of fuel. I am glad I changed it, the filter was the same color as my truck, black.
Old Oct 17, 2003 | 10:32 PM
frostie's Avatar
Re:fuel system
Thanks for the info. I will relay the info.
Old Oct 18, 2003 | 04:06 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:fuel system
It should definitely be full. Its possible that the lift is allowing fuel to drain back. Has he had a stutter at all during wide open runs?
Old Oct 18, 2003 | 10:10 PM
frostie's Avatar
Re:fuel system
He has had no WOT stuter. After a long pull a while back he pulled in and idled it and it had a miss. It does have low power. I out pull him in my first gen. ;D
RiverRat2
Oct 15, 2019 10:59 AM
ado2b1
Jul 6, 2007 09:35 PM
DISTURBED
Mar 11, 2007 09:14 AM
chucktownsend5
Mar 8, 2005 08:21 PM
