Fuel Sending Unit Assembly
Old Mar 9, 2010 | 10:20 PM
Adam8361's Avatar
Does anyone have a fuel sending unit they would be interested in selling? I have an 04.5 cummins and I think there must be a cracked pickup tube or something. Truck stalls out with fuel still in the tank. Happens at about 1/4 tank and the gauge is working properly. When it first happened I replaced the lift pump thinking that was the problem. I replaced with the same thing on the back of the filter assembly. The second time I took the fuel filter out and there was no fuel. I could here the lift pump running and making a sucking niose. Put a couple gallons in it and it was able to draw fuel. Anyone else had this happen?
Thank you,
Adam
Old Mar 10, 2010 | 07:58 AM
BarryG's Avatar
Try Vulcan Performance
http://www.vulcanperformance.com/category-s/220.htm
Look at the liberty modules with or without the drawstraw installed. Might work for you and significantly cheaper than the dealer item. Not postive it will work but worth a call. Works great on my 01.
Old Mar 10, 2010 | 08:08 AM
trailinone's Avatar
__
I was thinking the same thing. Good luck.
Chris
Old Mar 10, 2010 | 10:24 AM
SuperGewl's Avatar
Fill in your profile so we can help you better.
taylorjr94
Jan 22, 2015 06:39 PM
Chrisreyn
Jul 21, 2014 07:26 PM
Southern Pride
May 18, 2010 07:47 AM
JasonblkZ06
May 16, 2009 08:02 PM
figure_9_pro
Nov 11, 2002 08:53 PM
