Fuel Problem
Old Jul 18, 2020 | 07:32 AM
dadsdiesel's Avatar
Fuel Problem
2004 Dodge Ram 2500 SLT with the 5.9 Cummins. Truck runs great until I reach 1/2 tank of fuel. Then it starts to stall, spit, sputter and hard/won't start. I fill back up (usually 20 gal) it runs fine. Does anyone have any suggestions on what the problem could be? I've taken truck to two shops, haven't fixed the problem.
Old Jul 18, 2020 | 08:49 AM
FMB's Avatar
FMB
IIRC, some folks had issues with a cracked dip tube. As long as the crack was covered in fuel, it sucked fuel. When the fuel level dropped below the crack, it sucked fumes. Might be time to drop the tank. In my old '03, I dropped the tank to install a vent kit. This gave me an extra couple gallons of space for fuel. I'm not sure if the vent kit is still available, but if your tank is like my '03, it might be something you want to do while your tank is down.
Back to morning brew . . .
Old Jul 18, 2020 | 09:13 AM
dadsdiesel's Avatar
Fuel Problem
Thank you. A friend of my son made the same comment so I'm going to pull pump from tank. Thank you again.
Old Jul 18, 2020 | 09:28 AM
FMB's Avatar
FMB
You are quite welcome. I found the vent kit would apply to your '04 and the Description from Glacier is;
Description
'03-'12 Dodge Ram GDP Fuel Tank Vent Kit
Tired of waiting at the fuel pump to trickle the last 3 to 4 gallons into the tank on your '03-'12 Dodge Ram? Then this is the kit for you! This kit relocates the fuel tank vent from the factory location to the highest point on the tank. This allows you to add an additional 3 to 4 gallons to the tank while filling right up to the neck every time!
The GDP Fuel Tank Vent Kit uses only the highest quality 3/4" fuel hose along with brass and steel fittings (versus plastic) for a strong and trouble free installation on '03-'12 Dodge Rams. Spend your time on the road where you should be and not at the pumps!
______
Have a good weekend, back to morning brew . . .
kodeman84
Aug 7, 2011 08:46 PM
1970dodge
Oct 1, 2008 11:07 AM
robinlh
Aug 5, 2008 02:21 PM
camerd18
Jan 14, 2007 05:22 PM
WS6HUMMER
29
Sep 30, 2005 07:32 AM
