Fuel Presure...what is the stock reading?
Old Jul 5, 2004 | 09:29 AM
Diesel-Dan's Avatar
Did a fuel presure gauge on a 600 and found pressures to be rather low at idle....7-9 psi. We were able to drop the pressure all the way down to nothing with a hard blip on the throtle. 1. Is this normal stock fuel pressure? 2. Kinda seeing a pusher pump may be needed.
Truck has the TS Ramifier and injectors on it with EGT's still blazing....... I got it tapped on the pump from the line that runs to the bottom of the fuel filter housing. Thanks!
Dan "Mudinford" MacDonald
Old Jul 6, 2004 | 11:15 AM
bigblock2stroke's Avatar
I would get the pusher if I were you. Main pump is lubricated by fuel provided by transfer pump. You may have just lowered the system pressure because of the high flow injectors, but I wouldn't chance it.
Old Jul 6, 2004 | 11:19 AM
Diesel-Dan's Avatar
I will be installing a FASS on it tommrow. I just like the 17 psi worth of pressure....along with the 3/8" line.....and the air removing crap is OK too....haha.....
Old Jul 6, 2004 | 11:58 AM
thejeepdude's Avatar
Rumor is that the '05's will be finally getting rid of the lift pump and will have a pump in the tank instead. You could wait until they are released and see if that system can be retrofitted to an 04.5...
Old Jul 6, 2004 | 12:50 PM
Diesel-Dan's Avatar
Eh...its not my truck...I think the FASS will do nicely. I love it on my truck......These new Common Rails are a strange breed....still learing stuff...thanks!
Old Jul 6, 2004 | 04:23 PM
banshee's Avatar
That's normal stock pressure on the CR's at idle (~8psi). They usually drop to 4-5 at WOT stock, and with a small box (EZ, Ramifier, VA, etc) you'll get at or near zero.
John
Old Jul 7, 2004 | 08:46 AM
Diesel-Dan's Avatar
There we go! That is the answer I was looking for! Thank you much! I feel that 17 psi of the FASS will be a vast improvment.
mullishacrew
Mar 18, 2012 12:41 PM
BossHogg
Oct 24, 2008 09:54 AM
Ghost Ram
Mar 25, 2008 06:28 PM
simoniz
Nov 26, 2006 11:16 PM
