Fuel Pressure Problems
I have the Quadzilla Commander with the fuel pressure kit. A few months ago my FP readings started going to 0 then back up to 7 or 8. Quad had a new fuel sending unit that was suppose to fix the problematic old sending unit so I sent the unit off and got it back with a new transducer. Now my readings are around 6 or 7 while at an idle but when I step on it they will drop to the 0 - 3 range. My rail pressure always seems to be good so I am not sure if the lift pump is going bad or what. My mileage also seems to have gone down a little. The truck has 51000 on it and is an 04.5. If I take it to the dealer it should be covered under warranty but will they replace it if it is not totally dead? I am also not sure if the new transducer is working right. After the sending unit problems in the past I am not confident in its readings.
Any help would be appreciated. Also has anyone had any problems with the new transducers from Quad?
I recently installed a Quad Adrenaline on my truck with the Pulse monitor in cab. The first weekend, my fuel pressure would fluctuate between 7-8 most consistently, then go all the way in the 80's, and stay there. Later it would drop below 4 going all the way to zero. I had a Airdog on order. I just put it in 2 days ago, and it stays at 18-19 now. I made it drop to 16 on the interstate yesterday. That's the lowest it has gotten according to my Pulse monitor. I had the lift pump located behind the filter housing also, stock pump that is.
Chris
Chris
I notice in the Ads for AirDog they claim up to an 8% mph increase. Has anyone seen any mileage increase using this system? Also do you need to drop the tank to install a new draw straw with the AirDog 100.
dodgeguy71
17
Jan 19, 2012 12:52 AM
FastSS
Jul 19, 2004 12:16 PM
