Fuel pressure gauge question
Old Nov 20, 2010 | 03:22 PM
lastcall190's Avatar
I just was curious if this is normal behavior for a fuel pressure gauge. I have the gauge mounted inline right before the CP3, after all my filters. When I turn the key to "ON" I hear the raptor running and watch the pressure stop rising. After the pump stops running, the gauge is still reading pressure, and the pressure slowly drops down to zero. Is this normal? Or is the system bleeding off pressure somewhere and I need to track it down? Thanks
-J
Old Nov 20, 2010 | 09:14 PM
2007 5.9's Avatar
Yes that's normal bleed off of the pressure
Old Nov 21, 2010 | 06:10 AM
Great thank you
-J
Old Nov 22, 2010 | 08:42 PM
Fisherguy's Avatar
Sounds like you connected the Raptor to the stock pump wiring? There's a relay in there somewhere, pump will run for a few secs then power is shut off till you start the engine.
Old Nov 22, 2010 | 09:50 PM
bradler's Avatar
normal
dodgeguy71
17
Jan 19, 2012 12:52 AM
jimbo486
May 5, 2010 06:44 PM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
