Fuel pressure drops with power demand!
My lift pump was replaces about 5 months ago because the fuel pressure dropped below 4psi on my 2003. Chrysler replaced the pump for free(thank god) and put in the new style in the fuel tank.
My truck just sat for a day and first thing this morning when driving to work I noticed the fuel pressure drops about 1-2psi from the traffic lights and up to 3 psi if i floor it.
Not sure if my fuel filter might be getting clogged, its not that old? Could this new pump be on its way out already? At idle the guage is showing around 8-9psi, normal pressure which makes me think that the filter is not clogged?
Cheers
Cheers
i think that is typical of the pump that is a small pump with one chip on I can very easily pull the psi to zero. I replaced the entire fuel system on my truck and at idle I am at 42 psi and wot I am at 39 psi i would not worry about the psi on a stock truck If you bomb the truck go aftermarket pump soon or you may starve the cp3 and rail of fuel.
What kind of after market fuel system would you recommend? I was looking into that a while back and figured my problem was solved for the meantime. When they replaced the pump the pressure never dropped 3psi?
Can you run the stock injector pump at 42psi or do you have an after market one in there?
Cheers
Cheers
Your truck idles at 8-9psi thats high real high all of our truck run 4.2psi at idle then stay around 12 at 70mph if we turn our boxes up and get into it its aroun 16-18 with power level up but if running stock and get in it its up to 20-24 psi which is were it should be they say if your boxes are on and you get in it and rail pressure is below 20psi then your loosing 100hp. Glacier has a really good aftermarket fuel system alot better then the loud fass pushers if you ask me and theirs no splicing and noise they plug into factory harness.
Yes, you can run a lift pump (FASS or GDP) at higher psi with the stock cp3. I had mine at about 38psi with the stock cp3. You need to keep it set under 40 with the stock plastic filter cap. If you want to go higher than that, you will need a billet cover so it won't crack.
Where would be the best place to order a kit with all the fittings and so on. Best price of course. Googled up the pump, there is alot of information to look up? 2003 regular engine, not High Output.
T
T
In Tank Lift pump Mods
Ok guys, I see that the Walbro is probably one of the best rated aftermarket pump out there. I WANT ONE!
Chrysler replaced my lift pump about 6 months ago with the new intake design. After reading this I should have told them not to do that mod. Wondering if someone out there has an intake Walbro kit yet? Or is it worth it to switch back, I don't have the old plumming so not sure what that would involve switching back.
Suggestions would be appriceated and can you list best shop on here where one can find these pumps. Does anyone just buy the pump and get the fitting and fuel line from a third party?
Thanks
Thanks
Thanks
Thanks
Call Richard at http://www.glacierdieselpower.com/ and he can answer any and all questions you might have about the Walbro and install.
Dsg
DSG has a good pump. I just installed it very impressed, no cutting or drilling or crawling under truck. Alll for underr $300.
http://i166.photobucket.com/albums/u...feb1807001.jpg
http://i166.photobucket.com/albums/u...feb1807002.jpg
http://i166.photobucket.com/albums/u...feb1807003.jpg
http://i166.photobucket.com/albums/u...feb1807004.jpg
Marco
112
Feb 12, 2009 02:03 PM
jthorpe
45
Dec 16, 2008 09:08 PM
Marco
196
Oct 9, 2008 10:44 AM
dodgediesel4x4
Dec 3, 2004 03:57 PM
