Fuel Pressure?
Old Apr 16, 2005 | 04:17 PM
Bluedeviltorque's Avatar
Fuel Pressure?
I've read the few threads out there regarding fuel pressures on the 3rd gen trucks, but couldn't find anything really solid regarding a stock truck that is running correctly.
So what post filter pressures are you all seeing on a 03-04 H.O. motor with a healthy, stock lift pump assuming a clean filter and at full operating temps?
Mike
Old Apr 16, 2005 | 08:48 PM
Lightman's Avatar
With a clean filter I've seen as high as 7-7.5 at idle and 6.5 at cruise. 5000 miles into it now and I'm around 6.5 idle and 5.5 cruise.
Old Apr 17, 2005 | 09:43 AM
Maccandy's Avatar
My stock truck runs between 8 & 9 psi.
Old Apr 18, 2005 | 04:57 AM
Dodgezilla's Avatar
Mine stays between 6-8 unless I really get on it then it drops down to about 2 psi. On occasion it will drop to 0 on a hard run or if it's super cold out.....
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
