fuel mileage, dropped alot, ideas
Old Jan 5, 2012 | 08:10 AM
rockhound's Avatar
fuel mileage, dropped a lot, ideas
making it short
no chips on the rig, i live at 8700 ft elevation
magnaflow muffler, ats ehaust manifold, CAI, ats boost elbow are the only mods,
3.73 gears, '05, 3500 crew cab dually, 5.9, 156K on the odo, auto
truck is only seeing about 6000 miles per year at this time mostly long trips or towing 5th wheel, 10,000 lbs
november 2010, installed the boost elbow, truck began starting rough (real rough, lots of smoke etc.) and gas mileage dropped from 17-18 (empty) to 14, had complete BG service done complete motor flush, with no change ran ok when warm
mechanic said it needs injectors, had the entire truck gone through and it was determined that it needed a computer reflash, there was a service bulletin that fit my engine codes etc,
flash was done, truck runs great, gas mileage still sucks
what changed? any ideas?
Old Jan 5, 2012 | 11:53 PM
papaduck's Avatar
Winter fuel? Or could still be injectors.
Old Jan 6, 2012 | 02:38 AM
ramman's Avatar
Welcome the EPA and low sulfer fuel and or winter blends with kerosene which has less btu's.
"november 2010, installed the boost elbow, truck began starting rough (real rough, lots of smoke etc.) and gas mileage dropped from 17-18 (empty) to 14, had complete BG service done complete motor flush, with no change ran ok when warm"
Try removing boos elbow,check for boost leaks .JMO
Old Jan 6, 2012 | 12:38 PM
rockhound's Avatar
thanks, no leaks at boost elbow, after reflash truck run like new except for mileage,
it is not the winter mix, truck runs same crappy mileage all year now,
possible the new airflow is just calling for more fuel?
danimal 95
Jul 12, 2009 01:51 PM
DrBob
Aug 14, 2007 11:30 AM
farmer dave
Feb 6, 2007 11:27 AM
rfishbone
Mar 31, 2006 10:10 AM
TxDiesel007
Jul 17, 2005 05:03 PM
