Fuel leaks
Old Dec 4, 2012 | 09:38 PM
patriot dodge's Avatar
Fuel leaks
Put some dye in fuel and they ran a black light over it and said I had 2 leaks the #4 injector line which wasn't that bad and the fuel return line which is really bad, I am gonna try to do the injector line but not the fuel return line how difficult for the injector line, anyway to really mess it up, it looks fairly simple. Who to get the #4 injector line through dodge wants 64 dollars and Geno wants $23 but how are there lines. Thanks
Old Dec 5, 2012 | 08:11 AM
jhenson's Avatar
You will be fine going with the line from Genos. Also, contact your local Cummins dealer for a price.....might be cheaper. Should take no more than about 10 minutes to R&R. The return line will be a little tougher as it comes off the back of the head. Might try and reach back there and see if you can tighten it up....worth a try.
Old Dec 5, 2012 | 08:22 AM
47Dodge's Avatar
I got a spare #4 a while back from my Cummins dealer and it was 27$ and some change. Helped a friend change his #4 a while back and it wasnt 10 minutes to swap it out.
47
Old Dec 5, 2012 | 08:47 AM
OK thanks Iam gonna do the #4, I asked if it the return line was just loose and he said no it was cracked, they said that they have seen a lot of them that away because of the oil they put on the ground in the winter. I am not wanting to stretch around to try to change that one since I have a bad back.
abchoppers
Jan 26, 2011 05:38 AM
97catintenn
Jan 14, 2004 10:05 PM
jd knite
Aug 10, 2003 08:51 PM
KATOOM
May 2, 2003 05:19 AM
