fuel gelled injectors clogged
Old Apr 9, 2008 | 08:46 PM
Megaramasaur's Avatar
Are you sure that you didn't accidentally get gas into the tank? When I made my own bio in Alabama, I mixed some gas in with pure biodiesel in a jar, and it caused some waxy buildup on top.... kind of milky. Now this was with 100% bio that I hadn't water washed yet.
Is there anyway to flush your FCA? it may be plugged as well?
Old Apr 10, 2008 | 09:39 AM
high bid's Avatar
You could contact Texas Diesel Injection in SA on Toepperwien Rd. They would probably remove them for you and then send them to be cleaned, tested and/or replaced. Again, if I removed them I would contact M&D prior to TDI.
Old Apr 10, 2008 | 12:31 PM
Peterbilt's Avatar
I hope you figure it out soon. I've bought 20% in Cedar Park and had no problems. For some reason, I don't trust Shell.
Pete
(xploretx)
Old Apr 10, 2008 | 02:16 PM
hungabunga's Avatar
From: Canyon lake tx. just outside of New Braunfels
thanks for the responces and the tips...as of yet it isn't over with yet...i gonna keep changing filters and keep the block plugged in...some friends of mine have had the same trouble with the shell diesel here where i live...just found this out today..... i would like to find a solution without takin my truck in as it could easily happen again...from now on i will have a good additive on hand.........
Old Apr 10, 2008 | 03:07 PM
high bid's Avatar
regardless, if you sincerely believe it is a certain Shell station and others have experienced the same issues and especially with fuel from the same station then I would contact the Shell station owner. You shouldn't be expected to put up w/inadequate fuel that must meet industry fuel standards...regardless if it's bio blended. What is the address of the local Shell Station you've had problems with? I know several folks who live near by. Thanks for keeping us posted.
Old Apr 11, 2008 | 09:12 AM
hungabunga's Avatar
if you are comming from san antonio take south sam houston tollway and exit cullen, when you hit cullen , it is on the corner across the intersection ( i think i'm spelling it right, regardless, it is a few exits past bass pro shop)........i gave it alot of thought before i said anything, as i have been wrongfully accused before and it sucks, a persons words carry a lot more weight than most people realise...i thought about the possibility of a rat-turd putting something in my tank....but the same thing has recently happened to at least 10 other people that i know of, 1 was my nephew, another was a plant manager that i have known and dealt with personally for about 8 years.....
Old Apr 11, 2008 | 10:15 AM
John Faughn's Avatar
With the info you have now you should have the station pay the repair / tow bills , this is not an uncommon issue .
carwash
17
Nov 4, 2015 06:21 PM
Crossy's son
Jan 7, 2009 08:24 PM
hungabunga
Apr 9, 2008 12:16 PM
wcbcruzer
Aug 18, 2006 08:02 AM
mhuppertz
Sep 22, 2004 09:07 PM
