fuel filter wrench?
Old Aug 22, 2007 | 12:21 AM
hovisimo's Avatar
fuel filter wrench?
Curious what you use to remove your stock fuel filter cap... had to change it twice recently, crescent wrench is a pain given the close quarters and having to stand on the bumper. I vaguely recall once trying a socket and ratchet and it not fitting. A 1 1/8" stubby gearwrench would be nice but such a thing doesn't exist. Is there a better way?
Old Aug 22, 2007 | 12:55 AM
surfram's Avatar
1 1/8 socket on a long extension w/u-joint.
Old Aug 22, 2007 | 12:58 AM
tritont's Avatar
Fuel filter wrench
Old Aug 22, 2007 | 05:33 PM
leonesm's Avatar
1 1/8" Socket, 9" wobble extension and breaker bar. I use the breaker bar because of the swivel, not for torque!
Old Aug 22, 2007 | 05:44 PM
Alpo's Avatar
Changed mine out today,used a 1- 1/8 socket with a 1/2 drive ratchet.
Worked fine.....
Old Aug 22, 2007 | 05:57 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I know mine is a 2000, but according to part numbers, we have the same fuel filter and fuel filter canister. I just use a 1/2" drive 6" extension and a 1/2" drive ratchet. The male end of the extension fits right into the center of the canister cap.
Old Aug 22, 2007 | 06:58 PM
Fisherguy's Avatar
Worked fine.....
ditto, no issue at all...
Old Aug 22, 2007 | 07:15 PM
jwb600's Avatar
I use a big cresent wrench. doesnt leave much room but I adjust it tight to the top and take it off that way. seems to work for me
Old Aug 22, 2007 | 07:29 PM
06 DIESEL's Avatar
I would not recomend this method, you can and probibally will crack the lid. I use a 1 1/8" socket with a extension and ratchet.
Old Aug 22, 2007 | 07:34 PM
JPR Ram's Avatar
You're probably right, if you over tighten it that is. It just needs to be snugged down. I've never had any leaking issues from the o-ring.
Old Aug 22, 2007 | 10:32 PM
dadwolf2's Avatar
I just use a big crescent wrench. It's not on that tight and you just have to break it loose.
Old Aug 22, 2007 | 10:37 PM
Fisherguy's Avatar
lol
A crescent wrench will NEVER touch my truck!
Old Aug 22, 2007 | 11:00 PM
JPR Ram's Avatar
Originally Posted by Fisherguy
lol
Well, they're not called "nut rounders" for no reason.
Old Aug 23, 2007 | 12:10 AM
annabelle's Avatar
1 & 1/8 socket with a stubby ratchet. Harbour freight has a set of 1/4, 3/8, &1/2 ratchets for about $14.00. Or you can buy a 1/2 craftsman for a bit more.
Old Aug 23, 2007 | 07:05 AM
MikeyB's Avatar
I also have a Harbor Freight stubby swivel headed ratchet with 1 1/8 socket for just changing the filter.
MikeyB
