fuel filter questions
Old Jan 13, 2010 | 04:31 PM
firedoger's Avatar
I'm trying to figure out the fuel filter micron measurement means. Is the higher the measurement better ( 7 micron ) or lower better ( 5 micron ) ? I was in Nappa and they recommend the Napa Gold(wix) 3585xe filter. It's a 7mic glass media no metal filter. They also have the 3585 filter but it doesn't have the same micro rating.
Old Jan 13, 2010 | 04:49 PM
AH64ID's Avatar
The lower the better. The OE specs for a fuel filter are 7um absolute (98.7%), with 95% emulsifed/95% free water separation.
There are only 3 filters that meet this spec.
OE (Dodge/Fleetguard/Cummins)
Donaldson P550800
Baldwin PF7977 (Hastings FF1260), actually 5um absolute. Only filter to exceed OE specs.
The WIX (NAPA) filters are 7um nominal and do not meet the OE standards. They are 8um absolute. Wix does not care what OE specs are and have been quoted by several people saying "Its good enough".. A Wix fuel filter will void your fuel system warranty.
Old Jan 13, 2010 | 08:09 PM
LeaperV12's Avatar
You should go with the Baldwin PF7977, I switched over from Fleetguard.
So far so good for me
Old Jan 13, 2010 | 09:07 PM
NickBeek's Avatar
I have been using the Baldwin for many miles, I wouldn't use anything else in the stock location.
Old Jan 14, 2010 | 05:59 PM
DBLR's Avatar
Baldwin fuel filters for me
Old Jan 15, 2010 | 09:42 AM
kgagnon86's Avatar
so are hastings filters just as good as baldwin? one of the local parts houses that i have an account with, KOI (Kentucky, Ohio, Indiana) auto parts, carries hastings filters. i have always used carquest brand which is wix..
Old Jan 15, 2010 | 10:29 AM
sr4440's Avatar
has anyone used the AFE filter? It says it meets 3-micron
high-efficiency requirements
http://afepower.com/catalog/44-FF010/NPA.pdf
Joe
Old Jan 15, 2010 | 10:44 AM
Dr.Dizzle's Avatar
Joe
The D2 is not a fuel/water separator as per AFE. Given that information, this filter is not a viable option as it does not meet O/E specifications.
I currently use the Baldwin PF7977 which is the best you can currently purchase for the OE canister.
Old Jan 15, 2010 | 11:37 AM
AH64ID's Avatar
Hastings filters are baldwin filters.
Joe
The AFE D2 is 3um nominal, 7um absolute and is not a f/w sep. So its no better at filtering, and not a f/w sep.. Why they even manufacture this filter is beyond me.
Old Jan 19, 2010 | 11:10 AM
sr4440's Avatar
Thanks for the info!!!!
Joe
Old Jan 19, 2010 | 04:35 PM
mliming24's Avatar
when i had my 03 cummins, i bought a fuel filter from pure power. was a bit expencive but well worth it. its a stainless steel filter that u can wash and filters down to 1 mic. the web site is purepower .com
Old Jan 19, 2010 | 05:29 PM
AH64ID's Avatar
I would be curious how that does at f/w sep. It doesn't appear to be on their site anymore, can you find it?
Old Jan 19, 2010 | 06:08 PM
bansh-eman's Avatar
I was unaware that the Fleetguard did not meet the specs....
Old Jan 19, 2010 | 06:34 PM
Dr.Dizzle's Avatar
AH64ID,
I have attached the link to the fuel filter for your review.
http://www.gopurepower.com/store/ite...em&itemKey=708
Old Jan 19, 2010 | 06:49 PM
AH64ID's Avatar
The OE fleetguard? Yes it meets the specs.
Originally Posted by Dr.Dizzle
AH64ID,
Thanks.
