Fuel filter change....
Old Jun 4, 2004 | 11:04 PM
Jmac's Avatar
So is black normal?
Old Jun 8, 2004 | 12:03 AM
TON4FUN's Avatar
would a dirty filter affect gas mileage? I ordered a new filter today as my truck has 23K on it and I have never changed or checked my filter, I know, I know...... bad cummins owner.
Old Jun 8, 2004 | 11:32 AM
phox_mulder's Avatar
Yes.
But more important, it will affect "Diesel" or "Fuel" mileage even more.
phox
Old Jun 8, 2004 | 12:40 PM
TON4FUN's Avatar
You know what I meant. Thanks!
Old Jun 8, 2004 | 08:56 PM
cp's Avatar
cp
Yes, a dirty filter will affect mileage, but not in the way you suspect. If anything, mileage will improve.
Old Jun 8, 2004 | 09:35 PM
I beg to differ.
Dirty filter will result in less power,
one tends to floor it more to make up for it,
hence, worse mileage.
phox
Old Jun 9, 2004 | 02:13 PM
RockRover's Avatar
Hmmmmmm. Then were does the fuel go?
A dirty filter could (potentially) result in less power per a given distance of throttle travel due to filter restriction. Simply stating that more right foot leads to worse mileage is incorrect when talking about filter restriction.
Unless the fuel is hitting the ground and is not going to the injector rail, then mileage should be equal....To a point where the truck wouldn't run.
Now if your talking about mashing your right foot because of restriction, and thus holding it there until 6th (or 5th) gear...Well that's a different story!
-D
Old Jun 9, 2004 | 06:51 PM
cp's Avatar
cp
Originally posted by phox_mulder
I beg to differ.
phox
Feel free to differ.
But the fact is that you can't 'make up for it' by flooring it. As the last poster said, the fuel isn't going anywhere beyond the dirty side of the filter, regardless of throttle position. If it can't get to the engine, it can't get burned. Trying to get more fuel to flow through a restricted filter by 'flooring it' is pointless.
A restricted filter acts as a power reduction device, limiting the amount of power the engine can produce. You will have a difficult time pulling anything with reduced power, but mileage will increase simply because you don't have the power to overcome a lot of aerodynamic drag which is by far the biggest consumer of fuel. You'll have the full amount of torque at low rpm, but not at high.
BTW, that is the only way you'll ever know if you have a restricted filter--lack of power.
Old Jun 10, 2004 | 01:46 PM
stevenknapp's Avatar
But there is more than just fuel quanity, there is pressure and timing. Put your foot in it and you'll get longer injection durations but with less fuel flow. I'm not a combustion expert, but I could see this impacting more than total power output.
Old Jun 10, 2004 | 05:07 PM
cp's Avatar
cp
Nope. Pressure and timing are not affected. Only the quantity of fuel injected is affected, and it's just as if you put a stop under the accelerator pedal. As the filter gets more and more restricted, it's as if the block gets thicker and thicker. Finally, all it will do is idle. Then, nothing, if you let it go that far.
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
