fuel filter
Old Jul 10, 2007 | 01:11 AM
TexasCTD's Avatar
Here is a DTR Tech article written by member "Horsehauler". It has detailed instructions with pictures that should help.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Here is a great place to buy the filters.
http://www.genosgarage.com/prodinfo....mber=FS19856_P
Old Jul 10, 2007 | 01:41 AM
OR Mega Cab's Avatar
Originally Posted by EDWRDS
Do you have to drain the fuel? I change mine every oil change and I never drain mine?
Yes, drain the fuel from the fuel filter housing via the yellow handled valve. You do not have to drain the fuel from the tank if that's what you were asking.
Old Jul 10, 2007 | 10:29 AM
EDWRDS's Avatar
I know not the tank give me some credit but why the fuel filter housing?
Old Jul 10, 2007 | 12:00 PM
donhov's Avatar
You drain the filter housing to remove water and other contaminents in the bottom of the housing. You can then refill the canister from a can of diesel fuel you have on hand or you can bump the starter a few times with the cover off to get some fuel in the housing, or after replacing the cover and filter bump the starter to get some short runs of the fuel pump to fill the canister. Make sure to remove and replace the o-ring on the filter lid with the included new 0-ring.
Old Jul 10, 2007 | 07:38 PM
bighornram's Avatar
Anyplace is better to get a filter than the dealer. Paid over 40 bucks and left it sittin on the shelf in the garage when i found out they only gave me a 10 micron. Ordered 7 micron from Geno's for WAY cheaper.
sjester
Apr 17, 2006 10:06 AM
roc155
23
Mar 9, 2006 06:44 AM
Lunyfringe
Jan 10, 2005 05:40 PM
XTOAK
17
Aug 23, 2003 09:07 AM
turbo59pwr
Jul 9, 2003 04:24 PM
