fuel coming drip help!!!!
Old Nov 29, 2007 | 08:34 PM
Dwitt0187's Avatar
i have fuel dripping out of the bottom of my cp3 is there some kinda seal in there that can be replaced or do i have to replace the pump or can it be rebuilt by someone and upgraded somewhere please help
Old Nov 29, 2007 | 08:47 PM
Dwitt0187's Avatar
wheres the help i know this site is good about
Old Nov 29, 2007 | 08:50 PM
djbikeman's Avatar
Here is a thread that Rich2500 put together explaining how to replace the o-rings and seals with thicker ones, but it looks like the pictures are gone. I think he tells you the seals and o-rings you need though:
https://www.dieseltruckresource.com/...d.php?t=134295
The leak occurs because the two halves of the CP3 are different materials. As they expand and contract with temperature fluctuations, the seals fail slightly. You will see a lot of threads popping up about this.
Old Nov 29, 2007 | 08:54 PM
djbikeman's Avatar
You could also take a look at the Industrial Injection modified CP3. With the mods you have, it might help!
http://www.industrialinjection.com/m...odge+Fuel+Pump
There is also a DIY CP3 mod at relentless diesel:
http://relentlessdiesel.com/forum/viewtopic.php?t=19
You could do this combines with Rich2500's seal/o-ring replacement and kll 2 birds with one stone.
Old Nov 29, 2007 | 08:56 PM
Dwitt0187's Avatar
thanks man you are awsome i really need an upgraded pump is there anyone you know of that can rebuild mine and upgrade it????
Old Nov 29, 2007 | 09:01 PM
djbikeman's Avatar
I am already in over my head, so I'll let others pipe in. I am getting ready to get into the serious mods (Turbo, injectors, studs/rings, tranny etc.) so I have been reading a lot. That is where i got the above info.
There are some other guys on here that have a lot more info when it comes to mods.
There is also the DIY mod from relentless diesel which I added to the above post. Maybe a local diesel shop can handle this for you:
Old Nov 29, 2007 | 09:02 PM
Stovepipe03's Avatar
Just pull out the plastic and order this.
http://www.industrialinjection.com/m...Category_Code=
Old Nov 29, 2007 | 09:05 PM
Dwitt0187's Avatar
yeah i wish atleast the wife understands if the truck is broke it has to be fixed to get me to work lol
Old Nov 29, 2007 | 09:06 PM
Dwitt0187's Avatar
stovepipe03 you need to fill out sig to let us know about the truck
Old Nov 29, 2007 | 09:08 PM
Just tell her that you have to fix it "RIGHT" so it doesn't ever break again. It's a lot of money now, but think of the long term savings.
Old Nov 29, 2007 | 09:09 PM
It's WEAK WEAK WEAK.. I've been meaning to do that.
Old Nov 29, 2007 | 09:17 PM
Dwitt0187's Avatar
naw it is a sharp truck it'll get stronger just wait til the diesel bug bites
Old Nov 29, 2007 | 09:19 PM
Dwitt0187's Avatar
does the pump come out with the gear on it ????
Old Nov 29, 2007 | 09:22 PM
It's already trying to bite me. I know it won't be long, I just need to be educated a little then I will start the mods. I just have to balance between my truck and my car.
Old Nov 29, 2007 | 09:24 PM
Dwitt0187's Avatar
Good Luck The Just Remember The Car Is Already Fast Now Its Time To Make The Truck Out Run The Car
