fuel additive for the '03
Old Jul 1, 2003 | 08:56 AM
shaft's Avatar
Does fuel additive really help? If so, what brand would you recommend? I drive an '03.
Old Jul 1, 2003 | 11:32 AM
routerguy99's Avatar
Re:fuel additive for the '03
I have an 03' I also have a Neighbor that works for Cummins, he has stated to me that the Motor was designed to not to use any additives, if there is a fail it will be becouse of Mech., not clogged injetors. He stated its just a wast of money, he also showed me 2 injetors one with additives one without, I have choosed not to use additives.
Old Jul 1, 2003 | 11:44 AM
yz's Avatar
yz
I use Howes diesel treat with anti-gel in the winter. I also use it in the summer too by I am trying Lucas fuel additive right now. I might stick with it through the Spring/summer/fall. But I always use Howes in the winter. -Anthony
Old Jul 1, 2003 | 01:09 PM
lschultz's Avatar
I use Stanadyne Performance Formula and I get it here<br>http://www.dieselpage.com/add1htm<br>and I get a few tenths better mpg.I use it in the VW TDI and it does increase mpg.
Old Jul 1, 2003 | 05:05 PM
cp's Avatar
cp
No additives for me. Well over a million miles put on diesel vehicles without using additives and still waiting for my first clogged injector or inadequately lubricated injection pump.
Old Jul 1, 2003 | 05:41 PM
yz's Avatar
yz
What do you do in the winter. #1 or do you live some where in the south?
Old Jul 1, 2003 | 08:25 PM
Lightman's Avatar
You have nothing to lose using quality fuel additives and only stand to gain. The pour/gel point depressants in formulas like Stanadyne performance formula are great in the winter. Cetane boost aids in starting and power, considering the crappy 42 cetane average junk that's served up in the US, we need all the boost we can get. Other important functions of the additives are water dispersion and lubricity addtives. Lubricity additives add life to your injection system, and the dispersion additives will help greatly to prevent free water damage if you get a bad tank of diesel. Primrose Powermaster 405 for example, provides all those benefits, at a relatively low cost. 2.7 cents per treated gallon. Not exactly breaking the bank when we're talking about helping out a $45k vehicle... The only thing to avoid with additives is anything that contains alcohol, it could damage your injection equipment. A few gallons of biodiesel thrown in the tank will take care of the cetane and lubricity boost if thats all you're looking for...smells good too =]
Old Jul 1, 2003 | 09:14 PM
cp's Avatar
cp
You can learn a lot about diesel fuel and the role of additives here: http://www.chevron.com/prodserv/fuel...ltechinfo.shtm
Read up and you will find that there is no additive that has any effect on #2 cloud point, only pour point, and pour point is typically not the problem in cold temps--cloud point is. Mixing #1 with #2 is the only thing that lowers cloud point. Some additives claim to be able to modify the shape and size of wax crystals, but the effect is the same--a clogged filter. It just takes longer. This is something of a moot point anyway, as the Dodge has a heated fuel filter.
Boosting cetane does not add power, it primarily aids in cold starting. 42 cetane is more than adequate--Cummins only specifies 40.
As far as lubricity adding life to the system, as I said, over a million miles--still waiting for a lubricity problem to crop up.
Water dispersion (emulsification) is the last thing you want. Cummins puts a fuel/water separator on this engine to trap as much water as possible and keep it from going through the injection system--emulsifiers do the opposite: they send it on through. Your injection system will have digested every bit of water ever put in your fuel whereas left alone, the water separator would have prevent much of it from ever reaching your injection system.
Every one has a different opinion, and mine is no better than any one else's but adding fuel additives without understanding why demonstrates a lack of understanding of fuel oil and is, to me, a mindset not unlike the Slick50 crowd of a few years ago...&quot;Can't hurt, can it?&quot; was the motto when in fact, it actually could hurt. People, with minimal understanding of fuel oil properties, believe the fuel additive makers hype and repeat it verbatim when there is no way to substaniate what they claim.
In addition to recommending that biodiesel not be used, Dodge clearly states in the '03 manual, &quot;Note: In addition, commercially available fuel additives are not necessary for the proper operation of your Cummins Diesel equipped Dodge Ram Truck.&quot; Why would Dodge put that in the manual if, in fact, additives really were necessary?
edit: reworded to remove possibly offensive statements. I sometimes write things that aren't meant to sound offensive, but sometimes do. Apologies offered if necessary.
Old Jul 1, 2003 | 09:57 PM
cp's Avatar
cp
Gary, with all due respect, talking to few people does not make them (or you) an expert on lubricity. Or me either.<br><br>Are you saying that a.)today's #2 does NOT meet the lubricity requirements of ASTM D975, or b.)the VP44 pump needs lubricity above and beyond the minimum specified by ASTM D975? There is a huge difference. For starters, I don't think either situation is true, but assuming &quot;a&quot; is true, there would be pump failures galore. There aren't. If &quot;b&quot; were true, it would mean that Bosch somehow forgot how to build injection pumps when they made the VP44. Somehow, I doubt that, too.<br><br>And lastly, sorry I can't log a million miles in advance on some vehicle I don't own so I can report back to you from the future as to how the &quot;new&quot; pumps hold up. Until I can link up with Doc Brown, I guess the only experience I can offer up is the miles I've driven in the past--they'll have to do. But, BTW, over 250,000 of that million plus has been on Bosch pumps--with no additives, and no failures.
Old Jul 2, 2003 | 12:20 AM
Zeedaddy's Avatar
I use Stanadyne Performance formula...it makes the engine even quieter
Old Jul 2, 2003 | 07:40 AM
bulabula's Avatar
[quote author=shaft link=board=20;threadid=16570;start=0#155373 date=1057067801]<br>Does fuel additive really help?[/quote]<br>Thats a loaded question. Help with what? Mileage, longevity, reliability, emissions? Lightening your wallet?<br><br>According to Cummins, fuel or oil additives are not necessary on the 24-valve engine, provided factory recommended oil and fuel specifications are followed. Consult your owner's manual for proper guidelines. <br><br>I've got 12k on my truck, and have used a few of the fuel additives over the last 8 months I've owned it and didn't notice any difference. I've kept pretty good records on mileage and its been pretty consistent with or without. Sub zero temp starting and operation seemed the same with or without.<br><br>Keep in mind that producers of anything will try an entice you to purchase their product using whatever means they choose. Will additives harm your engine? I think its unlikely. Will it really help? I dunno. This all reminds me of the 3000 mile oil change to prevent the wiping your bearings mild hysteria/paranoia that we've all seen. <br><br>My thoughts are that low lubricity fuels have been around for a long time (jet fuel comes to mind) and industrial manufacturers know how to deal with the thier use. Its in their interest (profit $$) to know.<br><br>Clear as mud, I know. Go try some and let us know what you think.
Old Jul 2, 2003 | 01:44 PM
bulabula's Avatar
whew.... talk about thread hijacking. What was the original question? Fuel additives for an '03?<br><br>Look here at this service bulletin: http://www.fleetguard.com/pdfs/servi...3379001-07.pdf<br><br>At least it doesn't appear to be marketing propoganda like the other Bosch/Stanadyne et al pitch. And yes, it does discuss where additives can prove to be beneficial if using contingency fuels.<br><br>What's CARB? Maybe they'll be flipping burgers at mickey dee's in a month or two.
