front/rear diff -dealer claims 80/90 gear oil
Old Apr 15, 2009 | 02:39 PM
  #31
RowJ's Avatar
Originally Posted by Billy Ram
Yep some of the seals are not resistant to some of the synthetic oils base stock. " They will soften and fail" I have heard of folks replacing several seals before having to go to dino oil. Viton is about the only material not affected by the synthectic base stock. Billy
Sorry, just not accurate!
There is nothing in synthetic base oils that will hurt seals.... and Viton is for diesel fuel.
But...synthetic oils ARE more likely to leak if there is a seal problem!
Less contaminants and not as likely to 'slug up' due to better thermal stability will allow synthetics to find a leak where dyno oils won't.
RJ
Old Apr 15, 2009 | 07:27 PM
  #32
wiskeyVI's Avatar
My Blackstone report was waiting for me when I got home tonite.
I sent samples of Engine oil, trans fluid and the rear diff AMSOIL which I drew when I put in the RP.
The only one that was good was the tranny.
This is what is written for the diff (AMSOIL 75-140):
Iron was the most out of line in this sample, and it's cautionary. Iron, along with nickel, show excess
wear at a steel part. We aren't sure where silver and titanium come from in this type of system but neither
should read at this level, if you compare to our averages The viscosity of the oil was low. No moisture or
excess insolubles were found. We see that you had this oil changed and we hope that helps bring wear
down to more acceptable levels next time.
Old Apr 15, 2009 | 08:14 PM
  #33
Billy Ram's Avatar
That's why I like to use cheap oil and change it often. Some times you can find a deal on Mobil 1 but I haven't lately.
Billy
Old Apr 15, 2009 | 10:00 PM
  #34
wiskeyVI's Avatar
I used to do the same.
Guess I'm going back to that
Old Apr 11, 2010 | 11:02 AM
  #35
Stew130's Avatar
just checked alldata and it shows new TSB
NUMBER: 03-003-06
GROUP: Axle
DATE: October 20, 2006
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 03-001-04 REV. A, DATED MAY 11, 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE ADDITIONAL MODEL YEARS.
SUBJECT:
Axle Fluid Level
for our trucks (2500 and 3500)
either rear axle (8.25 or 9.25)
use 2.1L (72oz) 75w-140 synthetic
front axle (C205F)
use 1.6L (56oz) 75w-90 NON synthetic
both axles full level is 1/4" from bottom of the fill hole +(-) 1/4"
Old Apr 11, 2010 | 12:44 PM
  #36
NickBeek's Avatar
Steve, NONE of the 2500 or 3500 trucks have a 8.25 or 9.25 rear diff. They are 10.5 or 11.5. The front is a 9.25 ......
Old Apr 11, 2010 | 01:07 PM
  #37
torquefan's Avatar
I have serviced many differentials in Dodge and GM trucks, and the factory fill definitely does smell like grapes. However I have not found any other brand of synthetic gear oil that shares this smell. So the only thing that this proves is that the OP no longer has the factory fill in his differential. It is quite possible that that dealer uses a different brand of synthetic for servicing. Even if they have been refilled with dyno gear oil, I would not consider it a big emergency to change it back to synthetic.
Old Apr 11, 2010 | 03:43 PM
  #38
Danderson's Avatar
I serviced my rear diff@ 9000 K and it smelled like the bodies look like on CSI. Sour grapes would have been fine. I replaced w/Amsoil 75-90 Severe Gear and a Mag-Hytec cover. The front diff.@ 20,000K was like new.
Old Apr 11, 2010 | 08:06 PM
  #39
Stew130's Avatar
you are correct...my bad when i read the TSB the vehicle info was below the chart and looked like it was for the 2500/3500 when it was actually for the dakota
the 2500/3500 is:
10.5 rear 1" from the bottom of the hole +(-) 1/4" use 2.5L (85oz) 75w-90 synthetic
11.5 rear 1/4" from bottom of the hole +(-) 1/4" use 4.1L(138oz) 75w-90 synthetic
9.25 front 1/4" from bottom of the hole +(-) 1/4" use 2.2L(76oz) 75w-90 synthetic
hovisimo
Feb 13, 2008 08:22 AM
Joe Diesel
13
Aug 11, 2005 08:34 AM
Encryptic
Dec 18, 2004 07:40 PM
mazeppa
Jun 13, 2003 08:17 AM
USMC64-70
Nov 10, 2002 02:59 PM
