Front End Wandering !!!
Old Nov 15, 2005 | 12:01 PM
deezulsmoke's Avatar
Has anyone else had this problem on there truck ?? My truck is starting to wander all over the place with the front end. I cant imagine the ball joints already going bad on this truck. That is the only conclusion I can come up with. Has anyone heard of these new trucks having ball joint problems ???
Old Nov 15, 2005 | 12:31 PM
TorqueJunkie's Avatar
My '02 4wd does the same thing, I would also be interested if anybody has found a fix for this.
Old Nov 15, 2005 | 02:26 PM
ftltmp's Avatar
I havent had a problem with my 04.5 but my 01 wandered all over the place and this is what I did too fix it. www.lukeslink.com.
Old Nov 15, 2005 | 07:08 PM
leadpants's Avatar
I have had several people say that they have replaced the tracking bar. The tracing bar is all one piece and if it starts to wear you have to replace the whole thing. We used to by Moog as they had a life time warranty. That has changed this year (probably because they are all wearing so bad) to a 1 year warranty. They cost around $155.00.
Old Nov 15, 2005 | 07:15 PM
Geico266's Avatar
Have you tried tighten the steering box? It needs adjusting from time to time.
Old Nov 15, 2005 | 07:33 PM
sadlerb_98's Avatar
Mine does that too! Replaced ball joints and track bar. Still does it but not as bad.
Old Nov 16, 2005 | 10:45 AM
What is the best way to go about this?
Old Nov 16, 2005 | 02:21 PM
abc4yew's Avatar
Guys, I have an '03 and our track bar is suppose to be better than 04 and beyond track bar. I am going to replace my ball joints in a week or so. I have about 128,000 miles on the truck. They aren't toast and I not wandering but I have a toasted u-joint on the front and they are about 75% toast so I am erring on the side of caution. I'm sure I could go to 150,000 miles or more but I like to solve problems before they get bigger. I found spicer bottoms and moog tops. Both were slightly cheaper than stock and are nice looking greasable units. I would look at the steering box first. I understand there is a steering box brace for our trucks that makes the world of difference. Do a search on this and see what pops up. Good luck with your problem. ks
Old Nov 16, 2005 | 02:24 PM
abc4yew's Avatar
Oops forgot, check the steering stabilizer. A bent shaft on it can cause the truck to be all over the place. I hit the one on the f350 on hard snow and it bent slightly making the truck undriveable. ks
Old Nov 16, 2005 | 02:33 PM
Geico266's Avatar
On top of the streering box is a nut (approx 5/8's) with an allen screw in the center. Loosen the nut (while you have an allen wrench in the screw and turn the allen wrench about 45-60 degrees, no more than 90 degrees. Tighten the nut while keeping the allen screw stationary. Test drive by going around a corner and letting go of the steering wheel. It should return to the center (or pretty close) on its own. Do not over tighten allen screw.
This worked for me.
Old Nov 16, 2005 | 02:36 PM
Mr. Jimmy's Avatar
My 03 had a combination of worn balljopints and worn steering gear box replaced under warranty at 25K miles.
Old Nov 16, 2005 | 02:57 PM
This worked for me.
Thanks for the info!
Old Nov 16, 2005 | 11:06 PM
DrMoab's Avatar
I just took my truck in for a similar problem. It has 5000 miles on it and it suddenly lost all return to center feel. You could go around a corner on the freeway and if you let go of the wheel it would just keep going in that direction.
I took it to my cousin (who is the service manager at a dealer) and they replaced the steering gear. He said its the fifth one he has replaced.
When the took my old box out the sector shaft was screwed all the way in. They figured that was the problem.
He also told me that they have had tons of new trucks come in with frozen ball joints. When they bind up they will wander all over.
FROSTY1
Jun 10, 2014 02:59 AM
HelenaTDI
Dec 22, 2010 10:34 AM
Gordonville
Apr 18, 2005 09:45 AM
BigBlue
May 11, 2004 04:59 PM
