front end vib when stopping
Old Oct 3, 2006 | 01:04 AM
moparmatt's Avatar
yea when i hit the brakes when im turnin have a vibration in the front end i was wonderigng what it was i just receently put a 5 inch pro comp lift in...new trac bar and runnin 37iinch all terrains its an 04.5 any advice is appreciatied thanks
Old Oct 3, 2006 | 09:18 AM
nriver's Avatar
do you get any while starting? does the entire truck shake.
The reason I ask is mine did it after putting 37s on it. I am ~stock height in the rear and am not running that much lift. I thought it came from the front. The eitire truck would shake. Then I tried this, http://dodgeram.info/tsb/2004/03-003-04.htm
I just made a spacer from some square stock steel. I should order one of their parts, but it took care of the problem. Not sure if you have a long bed or not. It was a quick easy fix. If this does not work, then you will prob need to look into many other expensive parts.
Old Oct 3, 2006 | 09:36 AM
Thenewguy's Avatar
It could be the wheels are not balanced properly or brake rotor.
Old Oct 3, 2006 | 03:20 PM
nriver's Avatar
i shoud also say, check all the bolts....
move the rear tires to the front...
Old Oct 3, 2006 | 10:38 PM
moparmatt's Avatar
alright thanks a lot guys..sorry about the quick sloppy thread...i was gettin kicked off the net in like 2 minutes so i had to make it quick...it doesnt shake on start off... it just started the other day and only while i was braking in the corners anywhere else it was fine but it seems to have went away...it could be my brakes i was thinkin because i have 2 worn out anti rattle clips on the rotors and some slop in my brake pads.
moto953
14
Feb 21, 2008 11:25 PM
MrKen
Mar 31, 2005 10:59 PM
hobbes2
Mar 31, 2005 10:37 AM
Teddroe
Dec 3, 2004 12:16 AM
ckennedy
Oct 18, 2004 02:10 PM
