Front end noise
Old Oct 8, 2011 | 06:25 PM
MotoX999's Avatar
Front end noise
I have a 2005 Dodge 2500 4x4 and I am having a problem with a noise and I can not figure it out.. The noise sounds like I have big mud tires on, it happens when I am going 45mph+ and when I hit bumps that make the front of the truck sag it gets worse.. Also I only have 47k miles on it, I just put a left side wheel bearing on it, and it still has the same sound. Any help would be a big help to me. Thanks for your time.
Old Oct 8, 2011 | 06:34 PM
Rob's Red Ram's Avatar
Possible driveline ujoint? Rear axle bearing maybe?
Old Oct 9, 2011 | 04:26 AM
papaduck's Avatar
Welcome to the forum.
Check the front drive shaft. There should be no play in it, it has a cardon joint that uses 2 ujoints. If there is play in this joint it can cause sevear damage to the transfer case if it completly fails.
Also check the rear drive shaft ujoints and if you have the 2 piece drive shaft it might be the hanger bearing support.
Old Oct 9, 2011 | 09:08 AM
PWong's Avatar
Originally Posted by MotoX999
I have a 2005 Dodge 2500 4x4 and I am having a problem with a noise and I can not figure it out.. The noise sounds like I have big mud tires on, it happens when I am going 45mph+ and ---
Is the noise coming from the front tires? Swap the rear tires to the front and see-----.
Old Oct 9, 2011 | 08:48 PM
MotoX999's Avatar
I just rotated the tires and it was making the noise before and after tire rotation... I will check the front drive shaft. Thanks for the replys.
Old Oct 9, 2011 | 10:31 PM
AH64ID's Avatar
Do you grease the front drive shaft?
Old Oct 11, 2011 | 09:09 PM
MotoX999's Avatar
I can not find the grease fitting on the driveshaft.. I saw the picture on here that shows what it looks like I must have spun it around 20 times I can not find it.
Old Oct 12, 2011 | 05:30 AM
AH64ID's Avatar
If it's never been greased there is a change it is bad. Is there a shop/dealership local to you that could help you find it?
Old Oct 12, 2011 | 05:46 AM
papaduck's Avatar
Not all have a grease fitting. Mine does not. I am planning to use a needle and insert it through the seal and grease the u-joints. There is no way to get to the cardon center.
Old Oct 12, 2011 | 09:41 AM
AH64ID's Avatar
None of the u-joints have a fitting, but every Cardan I have seen does, even the ones where people thought there wasn't one.
Old Oct 12, 2011 | 12:52 PM
Scottygl62's Avatar
The grease fitting for that joint can be a real bear to locate, even when you know where it's at. Just a little dirt hides it. I find that I have to rotate the shaft slowly and really look to see it, and stick the end of a rag between the yokes with a small screwdriver to wipe away any old grease and dirt. Mine is a little sliver looking flush fitting. I use a small needle as the bigger needles don't work well. It's hard but needs to be lubed.
Old Oct 12, 2011 | 07:31 PM
papaduck's Avatar
I have had other vehicles with cardon joints and would grease them. My '03 does not have a grease fitting. I have looked at it very carefully.
Old Oct 12, 2011 | 07:44 PM
AH64ID's Avatar
The fitting on this Cardan joint doesn't have your normal grease fitting, it's the only one I have ever seen use it. It's quite hard to see on a dirty joint.
Old Oct 13, 2011 | 06:10 AM
papaduck's Avatar
It is just like the one I had on the 72 Blazer I had. Uses a blunt needle and it was sometimes difficult to get the grease to go into the joint. I looked for that grease point when the truck was new and have looked again later but have not found a grease point on the joint. The only grease fittings or grease points I ever found on the truck is the 2 tie rod ends.
Old Oct 13, 2011 | 08:40 PM
MotoX999's Avatar
I finally located the grease fitting, I greased it up tonight but didn't have time to take it for a drive to see if the noise changed at all. Thanks for the help
