front end bearings
Old Apr 24, 2010 | 09:50 PM
railroaderone's Avatar
front end bearings
I am having to replace the u joint and hub bearing on my truck at 53897 miles is thier any way to make these last any longer.
I use this truck as a truck it goes through water snow mud it pulls trailers stumps if a truck can do it mine dose and then some.
any help would be appericated
Old Apr 24, 2010 | 10:07 PM
annabelle's Avatar
Go to free spin kit and greasable u joint. My best solution any way
Old Apr 26, 2010 | 10:58 AM
Skyd Ram's Avatar
Yup,
Regardless of hub bearing brand, none of them will last much longer than others based on the unit bearing design. The idea is great for 1/2 ton gassers and smaller but because of the weight and use of our trucks they will all fail pretty quick. A Free Spin kit lets you install servicable bearings that are spaced farther apart to spread the load out more. The bearings are also replaceable with standrad off the shelf Dana 60 parts.
Old Apr 26, 2010 | 12:32 PM
billie's Avatar
Read this and make your own descision. I grease them.
https://www.dieseltruckresource.com/...bearing+grease
Old Apr 26, 2010 | 12:35 PM
cincydiesel's Avatar
I've been greasing through the abs sensor.. Still on the originals at 140,000
Mutt68
Sep 25, 2012 12:51 PM
Herrin811
Oct 3, 2010 07:22 AM
yfz431
16
Apr 30, 2010 08:36 PM
jetsnow
Sep 10, 2006 12:09 PM
Gordonville
Apr 18, 2005 09:45 AM
