Front Drive Shaft
Front Drive Shaft
I felt a vibration develop on the last month and finally found that it was my front drive shaft >>> actually the CV "Ball" in the front shaft... I pulled it out and apart and it is pretty much destroyed....
What is the least expensive way to get this fixed or replaced?
Is there a source for front drive shafts?? I checked Ebay and no luck there...
Oilguy
Oilguy
Check your local heavy duty truck shop. If they have a driveshaft repair, they can usually rebuilb the ball and socket. IIRC they call it a double cardan joint. If you tell them that they should know what you are talking about. NAPA has some kits available. The ball ( I believe ) is pressed onto the shaft. Not a major deal, but I usually let the driveshaft fellas do it!
TON4FUN
Aug 2, 2004 07:58 PM
