front divers side axel nut
Old Oct 11, 2015 | 02:10 PM
patriot dodge's Avatar
Tried everything to get off that axle nut to replace my hub but nothing is working, any suggestions would help, please. Thanks
Old Oct 11, 2015 | 06:21 PM
patdaly's Avatar
I ended up buying a 3/4" drive socket, about a 4 foot breaker bar for the socket, and used a pipe on the breaker bar.
They can be a bugger to get off.
Old Oct 11, 2015 | 08:23 PM
Asher's Avatar
put the wheel back on, leave off the hub cap. Put the biggest breaker bar you can get you hands on, on the nut, wedge it against the ground, get in the truck and put it in reverse and slowly back up, something is going to give, either your gonna breaker or your gonna break that nut loose.
This method seems to work best for me...
Old Oct 11, 2015 | 10:48 PM
I tried everything but that and it would not budge. I just dont want to break anything else. Any other suggestion before I try that. Thanks
Old Oct 11, 2015 | 11:12 PM
seafish's Avatar
Yes, instead of reversing the vehicle, jack it up by the drivers side axle housing 6-9" off the ground using a floor jack. Then securely attach the socket and breaker bar to the axle nut and orient the breaker bar so that it will move counter clockwise as the truck is lowered. Take a concrete or solid wood block and place it under the end of the breaker bar so it cannot move down when the truck is lowered, then SLOWLY release the floorjack so that the weight of the truck lowers against the breaker bar…this will be much safer then reversing the truck and should give enough CONTROLLED leverage to loosen the axle nut.
Old Oct 11, 2015 | 11:19 PM
Thanks I will gie that a try first.
Old Oct 12, 2015 | 01:28 AM
.boB's Avatar
Did you use a good penetrating oil; like PB Blaster? Hint: WD-40 is NOT a penetrating oil.
Old Oct 16, 2015 | 11:46 PM
seafish's Avatar
So did ya get'r done??
Old Oct 17, 2015 | 12:02 AM
Not yet been busy will let you know when I do it. Thanks
Old Oct 17, 2015 | 12:28 PM
Shorts's Avatar
Another trick I've read about is to use a jack under the breaker bar. Use it to crank the bar vs your own strength.
If I were doing this I'd be sure to guide/secure the bar so it doesn't slip off the jack or have the jack tip over.
Old Oct 18, 2015 | 02:49 AM
Steve-l's Avatar
It's all about having the correct tools. I use a 1" drive impact wrench. It will remove the nut or wreck the hub, but it will come off. If you haven't used one of these, get a helper to help you hold on to the wrench or it will rotate you.
bishgeo
Jul 26, 2010 01:27 PM
artieb
Mar 4, 2008 11:16 AM
Dr. Evil
Mar 18, 2007 11:28 AM
JImbo1
Apr 9, 2003 07:46 AM
