Front diff leaking in rear at front driveshaft?
Old Jul 6, 2013 | 07:13 PM
  #31
Nick060200's Avatar
BTW i dont think its blow by because like the other poster the top is not covered. i use synthetic 75w90. can i use something heavier? i dont use 4x4 often
Old Jul 10, 2013 | 02:53 PM
  #32
Shorts's Avatar
Originally Posted by Nick060200
would this be the seal?
just noticed a few days ago. i was thinking of getting a front diff cover with a sight glass so i can keep an eye on the fluid.
Yeah, that's your pinion seal.
Had the dealer do mine earlier this year when it let go.
Old Jul 10, 2013 | 04:36 PM
  #33
Nick060200's Avatar
Can it be let go for a while if i used a heavier oil and kept an eye on the fluid? Also does it only leak out when using 4x4?
Old Jul 21, 2013 | 06:33 PM
  #34
Rednecktastic's Avatar
Mine wasn't that bad but close. I had some old 75/140 (whatever the 1500 Ram uses). Not enough to fill it but I put that in when I changed the fluid and filled it the rest of the way with the lighter 75/90 syn fluid it calls for and it never leaked again. Kept using 75/140 and no more leak for like 4 years and sold the truck that way.
If the climate you are in is super cold I'd probably fix it but if you are in a warm climate just use the 140. I believe it meets spec, read your manual.
banana
Dec 1, 2009 11:44 PM
KMKDiesel
Jan 7, 2008 05:43 AM
Don H
Jun 7, 2005 01:01 PM
snice
Jan 5, 2004 10:25 PM
