Front diff leaking in rear at front driveshaft?
Old Dec 11, 2009 | 01:23 PM
billie's Avatar
The dealer replaced mine (warranty) and it cost me $1000 to fix it (after warranty), lasted about 3 months. Over-torque was cited as the problem by the next mechanic and it took out the whole thing. That was over 50,000 miles ago.
Old Dec 12, 2009 | 07:20 AM
dodge35000's Avatar
If it only lasted 3 months, I would have the dealer absorb the cost of the subsequent repair. I am quite sure that repairs done at Dodge dealerships are covered for one year from the date of the repair.
Old Dec 12, 2009 | 07:47 AM
dodge35000's Avatar
Originally Posted by MichiganAxle
The reaction torque at the pinion flange should be pretty darned close to ZERO in-lbs if this truck has any miles on it. The new seal will probably have 4 to 6 in-lbs of reaction torque on it when new. Be very careful when changing a pinion seal this way as if you have no pre-load on the pinion bearings you're going to spend a lot more money fixing it the 'right way' later on. Dealer tech probably doesnt know how to do ti the correct way (and most dont in all honesty - or dont have the right tools).
Dont forget the get the correct sealent for the pinion flange-to-drive pinion splines. Must be done and when that interface leaks is looks just like a pinion seal leak.
When I regeared my truck at 85K miles, my pinion torque to rotate was only about 3 in/lbs.
When I installed the new ring and pinion, I replaced the bearings, pinion seal, pinion nut, and installed a new crush sleeve. My final rotational torque readings were: pinion torque to rotate 19 in/lbs and total torque to rotate 37 in/lbs.
I agree that most dealer technicians do not know how to do this repair. I think that most of them would just zip the pinion nut off with an impact gun, replace the seal then zip the same pinion nut back on as if it were a wheel lug nut. I think that is why the earlier post(billie) had $1000 in repairs after he had the dealer replace his leaking front pinion seal.
Old Dec 12, 2009 | 08:32 AM
Bowser50's Avatar
Thumbs up I answered my own questions
looked in the manual it said everything I asked about. RTV on the spindle, take the wheels off, drop the front drive shaft, mark the nut and record the torque, got it I think im ready.
Old Dec 12, 2009 | 12:38 PM
Highway 4x4's Avatar
I had mine done by the dealer a few months back. They had the seal and the stearing gear replaced before noon. Maybe just a little too fast. I have a free spin kit waiting to go on as soon as I get some time. That should be the end of any future front end problems as I don't use 4 wheel drive that much. If the diff doesn't move it probably won't leak or wear. Also, I didn't have a front seal leak till I put full syn oil in the front diff. I've heard the syn oil leaks more.
Old Dec 12, 2009 | 04:15 PM
billie's Avatar
Yes, but it was my choice not to. Its a long story but it was the last time they touched my truck.
Old Dec 13, 2009 | 01:16 PM
Bowser50's Avatar
Yeah I did go to royal purple in the diffs that may have been it but the truck does have 60k on it too it probably was just time to replace it.
Old Dec 17, 2009 | 07:25 PM
justin mcfall's Avatar
Just got this repaired today on my 05..Paid the $100 deductable and that is it..84,000 on the truck...
Old Dec 17, 2009 | 08:53 PM
HorseHauler's Avatar
hmm I need this done on my truck too. I have 86,xxx on the truck. Tell me more about this $100 deductable?????
Old Dec 18, 2009 | 09:06 PM
Rednecktastic's Avatar
I'm throwing a freespin kit on mine and going to fill it with the thicker lube up front... The 140 syn lube to slow it up a little.
I haven't ever had to add any oil to it though, it just has some oil on the surface.
Old Dec 19, 2009 | 11:20 AM
92'1stGen's Avatar
Looks like I'm going to need to do this too as the seal just started leaking within the last few weeks. I think I may tackle it myself though as I have no faith in the dealer for something this complex and delicate. Just another reason why you should purchase a free spinning hubs kit for the front end.
Old Dec 19, 2009 | 11:52 AM
Leaks are done, knock on wood, the free spin is in.
Old Dec 19, 2009 | 11:53 AM
CamperAndy's Avatar
When my truck had about 5,000 miles on it, my seal was wet but not leaking (drops on the drive way). I had a free oil change at the dealer so asked that they replace the seal at the same time. They said with a straight face it was engine blow by that made the area wet with oil. I asked them how much oil was on top of the differential and they said again with a straight face, not any as it collects on the bottom of the differential. This was the last time they will ever see my truck.
I did notice that when I changed the differential oil the first time I use dino oil instead of syn and the weep stopped. The second time I changed it I went with a full syn oil and it is weeping again. Both oils were the correct weight and both were GL5 spec. Next time I change I will go back to dino and see what it does.
Old Dec 21, 2009 | 08:47 PM
Bowser50's Avatar
**** camper I feel bad for you those guys were idiots **** I don't know much but I know that blowby don't start at the bottom of a diff hope all works out for ya. Yeah I will go to a normal oil again when it comes time to change it again. I think I will go with lucas.
Old Jul 6, 2013 | 07:09 PM
Nick060200's Avatar
would this be the seal?
just noticed a few days ago. i was thinking of getting a front diff cover with a sight glass so i can keep an eye on the fluid.
Attached Thumbnails Front diff leaking in rear at front driveshaft?-img_0593.jpg
