follow up on 47-48
follow up on 47-48
HI, I'm kinda confused and startin to get mad, bought my truck use from dealer, specificly asked it trans was 47 or 48, they swore it was a 48. Been readin old post on subject and it would appear they lied(imagine that). My build date is 11/02. Is there anyway for me to be able to tell for sure which tranny i have before i blow a gasket down there?? Could sure use some input. thanks
Re:follow up on 47-48
got two trannys marked in box forst says DGB 2nd says DGP????????? both say 4 speed A on first Au on second is this crazy or what??
1 Post
I may be wrong (been known to do that), but I believe the first set of numbers is for your transfer case. I think I'm right about this one though...they didn't make the 48RE yet when your truck was built.
My truck was built in Dec 02. I have the exact same codes you have, in the same order as well, and I have the 47RE. Even said so on the window sticker when I bought it. Sorry man....
Thanks guys i,ve been doin a bit more research and found one web site that gave id location on trans, drverside just above oil pan. Will check it out tomorow, who no's maybe ill end up with an 04 lol thanks again cya
