fluids
Old Jun 30, 2008 | 03:18 PM
ian515's Avatar
fluids
what should I be using for the diff fluids, and tranny fluids? while the truck is down and out, I am gonna change all that.
Old Jun 30, 2008 | 03:46 PM
paroxysym's Avatar
i plan on changing the diff fluid on mine soon as well- so im wondering whats out there. im thinking of running synthetic since i do everywhere else.
Old Jun 30, 2008 | 05:45 PM
VaultRam's Avatar
I just put in Valvoline Syn. for the tranny. As for the diffs, use anything that is GL-5 rated....whether that"s Amsoil, Royal Purple(pretty pricey stuff) or any regular 75w90(also GL-5 rated). I heard if ya tow heavy alot to use 75w140 in the rear>
Old Jun 30, 2008 | 07:07 PM
Roperteacher's Avatar
Correct, I am using 140 in the rear because I tow heavy and in a hot climate. I have the AMSOIL in there now but even with prefered pricing I am thinking i am going to go with Mobil 1 Synthetic 140 next round!
Old Jun 30, 2008 | 10:37 PM
Jeff in TD's Avatar
The book says warranty requirement is GL-5 Full Synthetic 75-W90 for the axles. My dealer says 75-140 for people who tow in hot climates. I've run Redline 75-140 in this truck and my last truck with good results.
I'd also say don't torque the cover bolts down to what the book says. Several people have had a bolt or two snap off. On my last truck, first change went fine, so I figured I wouldn't have any problem. Second change, though, one snapped off without even getting close to the ft/lbs specified.
Transfer case takes a bit over 2 quarts ATF+4.
Old Jun 30, 2008 | 11:57 PM
PML covers like mine have a nice drain plug!
Old Jul 1, 2008 | 02:06 AM
SuperGewl's Avatar
ATF+4 is synthetic.
I run nothing but AMSOIL thruout
Old Jul 2, 2008 | 12:55 PM
DBLR's Avatar
Down and Out, what did you do now?
As for diff I used Amsoil sever gear 75/90 and if your towing part time an some what heavy you could use 75/110 and it not be affected by the cold winter temps. In my trans I used Amsoil ATF as I know it holds up better then the factory ATF that Dodge used.
Old Jul 2, 2008 | 02:52 PM
ian515's Avatar
I KNEW you were gonna see this and comment. when I posted this, the rear driveline was taken out, and the shop was putting new U Joints in. but 2 hours later it was back up and running again!
thanks for the advice on the fluids guys.
Old Jul 3, 2008 | 03:11 PM
DBLR's Avatar
I get it you just wanted to see if I was sleeping!
Srigs
Aug 7, 2003 06:29 PM
towin1JT
28
Jul 31, 2003 05:30 PM
Max
May 20, 2003 10:02 PM
AKDSLDOG
Apr 6, 2003 08:27 AM
ARAcummins
Feb 24, 2003 06:22 AM
