Fluid/Oil In The Driver Side Engine Bay
Old Jan 10, 2007 | 04:19 PM
VaultRam's Avatar
Well I just got back from a 600 mile trip and smelt oil or something of that nature coming from under the hood. Looked under the hood and saw that only on the drivers side that fluid was spackled(sp?) on the firewall, on the coil spring and shock tower, steering box, several hoses and most of the front diff. I know that there is a tube that aloows excess(sp?) fluid out but this seems alot. I check the oil and the level is fine and the tranny fluid is exactly where it needs to be! Does anyone know what migh have happened or is causing this?
Old Jan 10, 2007 | 04:27 PM
smokindog's Avatar
I'm not sure if they changed anything on the 3rd Gen A/C routing, but the liquid line that runs along the passenger side fender from the condenser to the evaporator core tends to go bad from all of the vibration and when it does the small amount of oil in the system could cause what you have experienced.
Is it a small amount? Dark black like motor oil? Just something to consider.
Old Jan 10, 2007 | 04:37 PM
VaultRam's Avatar
Im not sure what a small amount would be with these trucks. Its enough to almost cover the front diff, some of the driverside coil spring, firewall and all other hoses in that area!
Old Jan 10, 2007 | 04:51 PM
VaultRam's Avatar
Forgot to mention it looks like dark black motor oil and has the viscosity(sp?) of it too. Then again the roads here in colorado are crappy from the snow storms so the undercarriage is real dirty!
Old Jan 10, 2007 | 04:54 PM
John Faughn's Avatar
Did you check your power steering ?
If its just speckled , then maybe you just drove through something , look at the tire to see if you can see a sign of splash off it .
Old Jan 10, 2007 | 06:19 PM
djbikeman's Avatar
I had on oil leak on my truck when it was new. it was an accessory cover plug that is located on the front of the motor just slightly higher than the Injection pump (CP3).
Also check and make sure it's not diesel fuel. It could be a leaking injection pump.
Can you follow the trail and see where it is coming from underneath the truck?
Old Jan 10, 2007 | 07:10 PM
VaultRam's Avatar
I looked for about 15 minutes and couldnt find the source. It looks like it could be coming from one of the two hoses above the steering gear that run back towards the tranny. I will look again tommorow, but will probably end up taking it to the dealership Friday. Thanks for the picture...I will check that and as far as diesel I didnt smell it but it felt like oil!!
SaskAttak
Oct 24, 2012 07:19 AM
Bushmaster
Jan 4, 2011 08:05 PM
pybyr
Jul 30, 2006 09:33 AM
96RAM
Dec 27, 2005 10:15 PM
mucknet
Jul 18, 2005 11:23 PM
