Fluid interchange
Old Jan 7, 2018 | 05:07 PM
Totallyrad's Avatar
Fluid interchange
Hey guys, what are you using for an off the shelf replacement for the synthetic rear differential fluid on an 04 3500 dually? I noticed a wine or ringing and found my rear fluid about 3/4" below the bottom of the plug.
Old Jan 8, 2018 | 11:05 AM
pdogg's Avatar
Mobil 1 75/90 full synth, or previously I used Valvoline full synth
Old Jan 8, 2018 | 04:10 PM
Totallyrad's Avatar
So today I visited the dealer. The fluid part number has changed and it does not include the friction modifier for the limited slip. I bought the friction modifier and passed on their $19 a quart GL-5.
Old Jan 8, 2018 | 07:36 PM
madhat's Avatar
Administrator/Jarhead
I just use the walmart brand.
Old Jan 9, 2018 | 01:49 PM
pdogg's Avatar
Pretty sure you don't need the LS modifier for our AAM 11.5 axles, they are mechanical helical gear lockers. From the manual: NOTE: Trac-Lok differentials require Limited Slip
Additive in the lubricant. Trac-Rite™ differentials DO NOT require Limited Slip Additive.
It's my understanding we have Trac-rite rear diffs in 3rd Gen.
That being said, it will not hurt the diff to have that in there.
Old Jan 9, 2018 | 09:49 PM
torquefan's Avatar
Not sure, but I seem to recall the proper fill level on those AAM axles being a half inch or more below the fill plug. I can't remember if the owner's manual has that info, or if you need a shop manual.
Old Jan 10, 2018 | 02:26 PM
pdogg's Avatar
this is correct, 1/2" below fill hole.. I just replaced my fluid this past weekend.
el jefe
Oct 19, 2005 06:26 PM
360ramcharger
Jul 7, 2005 08:16 AM
furious70
Sep 2, 2003 10:39 AM
