Fleetguard Oil Filters
Old Feb 18, 2007 | 05:47 PM
  #31
moterhead's Avatar
I use the LF3894s on my '04. Have since I did the first oil change. I use a KD band type wrench and a long 3/8 extension. No access problem at all. Yeah, a buck price difference over 7500 miles isn't much, but, hey, it's the SAME filter & I don't use the flutes anyway. Better a buck in my pocket than someone else's. I change 'em from the bottom. I'm under there anyway doing things like removing oil pany drain plug, reinstalling oil pan drain plug. That sort of thing. I have no access problems at all. Don't know if the '04.5 and later trucks have more obstructed access or not. Never worked on one.
Old Feb 19, 2007 | 09:13 AM
  #32
dezeldog's Avatar
Originally Posted by P.J
$.34 more than at www.genosgarage.com
How do you figure??? Invoice from scheiddiesel says $9.26 and Genos is $9.50 I think thats .24 the other way. Like I said scheiddiesl is cheaper. Again no affillation.
Jim
Old Feb 19, 2007 | 10:02 AM
  #33
belgianmagic's Avatar
Originally Posted by dezeldog
I get my filters from here.....www.scheiddiesel.com. Best price that I've found. I use the 3894 on my 03. I have a short handled filter wrench and have not had a problem changing them. No affilation!!!
Jim
you need to check again...here is what their page says........
http://www.scheiddiesel.com/filters.htm
'00-'02 Dodge Cummins FS19579E Add to my cart! 10micron LF3959 Add to my cart! LF3894 Add to my cart!
unless I'm reading wrong that filter is for 00-02
Old Feb 19, 2007 | 10:51 AM
  #34
dezeldog's Avatar
Well I,ve been running the 3894 now for 100k with no ill affects and oil samples always come back "all elements are acceptable....change oil and filter and resample at normal intervals" I guess thats good enough for me.
The price that I quoted was from an invoice from scheid that was dated Dec. 27. Thats all I have to go by.
Jim
Old Feb 19, 2007 | 10:57 AM
  #35
P.J's Avatar
P.J
Jim
Uh, yeah.
Might want to investigate that a little further.
(No affiliation with GENO'S)
Old Feb 19, 2007 | 11:06 AM
  #36
dezeldog's Avatar
Uh, yeah.
I think I already covered that. Have a great day....
Jim
Old Feb 19, 2007 | 11:11 AM
  #37
dezeldog's Avatar
I JUST WANTED TO LET YOU KNOW it was the wrong filter...as long as theres no problem...
You might want to reread posts # 29 and 30. What else can I say.
Jim
Old Feb 19, 2007 | 02:26 PM
  #38
P.J's Avatar
P.J
It's just what happens when phrases like "How do you figure" are thrown around.....
Old Feb 19, 2007 | 04:24 PM
  #39
dezeldog's Avatar
Is that the same as "might want to investigate alittle further". Unless there has been a price increase in the last 60 days I stand by my statement until proven otherwise.
Jim
Old Feb 20, 2007 | 06:45 AM
  #40
P.J's Avatar
P.J
Whatever you say fella.
Old Feb 20, 2007 | 06:56 AM
  #41
dezeldog's Avatar
Thank You Fella!!
Jim
Old May 8, 2007 | 01:02 PM
  #42
you know...SEEING REALLY SHOULD BE ,BELIEVING
I gave you the links to show you Genos price is cheaper...BUT I was NOT HAPPY with their support team....
I ordered a case of filters that took 2 weeks to get here from GA...I could have carried them home in a wheel barrow faster...
Old May 8, 2007 | 03:19 PM
  #43
sdmark's Avatar
I am a true D/A? Can someone, anyone compare this to the K&N oil filter I am running? I am sure the fleetguard is the way to go but free is good unless you get junk.
Old May 8, 2007 | 04:04 PM
  #44
AS SEEN IN POST #8 ON THE FIRST PAGE OF THIS THREAD...CHECK OUT THIS LINK
the Stratapore filters more with less obstruction...easier flow better filtering
the filtering material is not paper like most other filters........CHECK THIS LINK OUT http://www.cumminsfiltration.com/en/...ratapore.shtml
Old May 8, 2007 | 06:38 PM
  #45
CTDinMT's Avatar
Anyone know if the Mopar MO285 is a stratopore? It looks identical to an
LF16035. Wal-Mart had them on sale a while back...
