Fleetguard FS19800E
Old May 10, 2006 | 07:19 PM
tony's Avatar
Fleetguard FS19800E
I've read that Fleetguard FS19800E is a finer micron version of FS19579, but although I could not verify this with Fleetguard I ordered this filter. I received the filter today and it does not appear to be a direct replacement.
The primary visual difference is the end caps. The end caps on FS19579 are a thick pliable material about ¼" thick. The end caps on FS19800E are a hard plastic about 1/16" thick, but the opening for the standpipe appears indentical to FS19579. I have an extra cap and it appears to fit in the diameter, the thinner end cap allows quite a bit of axial movement.
FS19579E, based on the picture on the Fleetguard website, has similar caps to this filter. Should I have ordered FS19800 (if one exists)? Does this fillter use a different lid, or is this simply the wrong filter for a 3rd gen?
Thanks!
Old May 11, 2006 | 10:44 AM
KENNETHMD's Avatar
NEW fuel FILTER
I do belive that is the new 7 micron fleetguard that is now standard issue in the 2006 (it bettter be i ordered 3 for my 2005) from geno's
Old May 11, 2006 | 12:16 PM
MikeyB's Avatar
Appears to be the correct filter.
http://www.fleetguard.com/fleet/pdfs...s/np5-2006.pdf
MikeyB
Old May 11, 2006 | 12:36 PM
KENNETHMD's Avatar
MikeyB
Thank's for the info I feel better now.
Old May 11, 2006 | 01:05 PM
RC51's Avatar
Anyone else notice the new fuel filter for the 2007's on the next page of the fleetguard link? What is the sensor for? Bet this will make Fuel Filters more expensive!
Old May 12, 2006 | 10:49 AM
jkitterman's Avatar
The sensor is most likely the water in fuel sensor.
Old May 12, 2006 | 11:19 AM
IA_James's Avatar
Says it's spin on also, so no more fragile platic caps on the canister sounds like. Now we'll see if they put it somewhere accessible.
Old Aug 3, 2006 | 11:34 AM
TonyB's Avatar
BTT...only cause I missed it and was about to duplicate the post!
From the bits and peices I've been able to glean from the filter manufacturers, DC, and earlier posts....
New filter DC 68001914AA $38.17 Dealer has on order
Fleetguard FS19800E $14.95
Cummins FS19800E $16.65
From Geno's garage and the fleetguard link, the FS19800 is listed as a 7u vs. FS19579 at 10u.
HTH
Tony
Old Aug 3, 2006 | 12:53 PM
ptgarcia's Avatar
So does that mean the FS 19579 filters I just received in my maintenance kit from Geno's are the wrong filters? Should I send them back/exchange them for the FS 19800E?
Old Aug 3, 2006 | 02:12 PM
TonyB's Avatar
I would...I just ordered the FS19800E's; They match up to the PN of the new DC filter.
I'm also considering a 2u-4u filter. Not sure when, but I'm considering it!
Tony
Old Aug 3, 2006 | 03:25 PM
ptgarcia's Avatar
I pulled my owners manual and it specs Mopar P/N 05015581AB for the fuel filter. Is there any way to tell if this is a 10 micron or 7 micron filter?
Old Aug 3, 2006 | 03:31 PM
ptgarcia's Avatar
Well I just answered my own question. On the Fleetguard/Cummins Filtration site cross referencing Mopar P/N 05015581AB pulls up Fleetguard P/N FS19579E.
Almond Pale Ale
Jan 21, 2007 08:59 AM
FMF MX
Feb 6, 2003 05:25 PM
Tom
15
Jan 8, 2003 05:14 PM
tishmael
Nov 7, 2002 11:38 AM
