first oil change...
Did it yesterday, no problems at all,I was able to reach the filter with my arms and twist it off by hand. A wrench will definitely be ordered to make it easier next time, especially with an extension attached, but I managed, I suppose the hoist helped the access to the filter as well.
Thanks again for the info!!!
Never use a wrench to install the oil filter. Just do it as hard as you can by hand, with the threads and gasket lubed with new oil.
I prefer to drain the oil hot-- it will have more crud in suspension then, and the thinner oil drains much faster.
I've become of a fan of the PIG flexible funnels, but on a CTD you don't really need one. But if you're worried about splashing, you could use one to create a "ramp" that will prevent that.
Check it out-- my local Napa carries them.
http://www.formafunnel.com/
Also, you might want park slightly nose high to help drain all the oil out.
1. Lube the seal
2. Tighten by hand
3. Turn 3/4 more with wrench (I always thought this was too much so that's why I only do 1/4-1/2.
Owners manual says 3/4 of a turn after contact. General consensus on the net is: as tight as you can by hand +1/4. This is the way I've done it for as long as I can remember. I will say though, since I switched to synthetic oil, the filter does seem to be easier to remove.
The instructions are correct. But they produce a filter installation that is almost impossible to remove.
Personally, I don't like needing to chisel off the filter. I've been installing mind without a wrench (hand tight only) for 9 years.
Never had a problem with leaks. Like AH64, I STILL struggle to remove the filter even when only installed hand-tight.
YMMV.
YMMV.
YMMV.
I guess this was a good subject to bring up. Out of all the reading I've done on this forum, I can't remember coming across this subject. Seems simple but it's never really discussed. I didn't know there were people out there who only put their oil filters on hand tight. This has been an eye opener for me. I have a feeling there are many others out there who are thinking about their next oil filter install.
Here's a pic of the setup that works really good for me:
jmccart
13
May 27, 2009 09:45 PM
1stTimeAround
Oct 10, 2004 04:02 PM
doitl8r
Jun 4, 2004 11:14 AM
snice
14
Apr 29, 2003 08:41 PM
pwabbott
Nov 15, 2002 03:28 PM
