finally installed my mitchell over drive!
Old Sep 25, 2007 | 09:42 AM
TonyB's Avatar
Is there a website for Mitchell? Even if there's only a listing and potential sources.
Tony
Old Sep 26, 2007 | 06:34 PM
supersonictoys's Avatar
you might want to back up top and read the part about how they ae no longer manufactured.....
Old Sep 26, 2007 | 06:53 PM
NickBeek's Avatar
OK then exactly how did you find yours? Where can we start hunting? What was the original vehicle the unit was designed for? C'mon share the love.
Old Sep 27, 2007 | 08:45 AM
PADZZ's Avatar
What dunes are those?
Old Sep 27, 2007 | 10:48 AM
JohnInNH's Avatar
Towing in 6th over is not a problem for the GV unit, but rather for the overdrive gear in the 6 speed G56 unit.
My GV unit only drops my RPM by about 500.
I would rather have the +22% so I can tow in 5th over (direct drive) and have the same ratio as the factory stock 6th. Then have a wicked nice OD ratio in 6th for light loads and empty... Even heavy when having a tail wind on the flats. I look more at the load (boost & EGT) If it's working hard I shift from 6th over to 5th over.
This is the best for longevity of the G56.. It runs cooler and will not beat up the little OD gear in the G56. Running HEAVY in 6th over will beat up your G56.
You may want to rethink you OD gearing choice and consider running in 5th OVER when pulling any real weight.
I do like your set up! I would have preferred it as it does not have the reverse "issue" Also no electronic crap. My GV is doing some weird stuff like not shifting into OD sometimes when I first use the truck. Also after using 4x4 you have to shut off the ignition to reset the lock out.
The weak link in your 6th overdrive is the G56.
Your set up is VERY COOL!
jk6140
Jul 22, 2007 01:26 PM
Racing_Joe66
Jun 12, 2006 08:00 PM
jman6716
Oct 10, 2004 11:05 AM
fahlguy
Nov 16, 2002 03:58 PM
Sarge1124
Nov 13, 2002 01:40 PM
