Fill Oil Into Manual Transmission
Old Oct 13, 2008 | 11:58 PM
banana's Avatar
How do I fill ATF4+ into the manual transmission (6speed), without making a huge mess?
Old Oct 14, 2008 | 12:52 AM
98whitelightnin's Avatar
Pull the stick out, its not the easiest way but definatly the cleanest. Or you can do like i did and park in a ditch or on a steep hill and use a hose attached to the bottle.
Old Oct 14, 2008 | 04:31 AM
homewrecker's Avatar
Or use a small elec. pump if you have one.I have one but still prefer to pull the shifter so I can get an extra quart in.On the NV5600 its recommended to overfill by a quart,not sure about the G56.
Old Oct 14, 2008 | 06:39 AM
Guardrail's Avatar
I poured my trans fluid into a gear lube bottle and used a tube attached to the nipple end of the bottle. Why are you using ATF+4 in a manual trans? Mine called for the "special" fluid from Chrysler.
Old Oct 14, 2008 | 06:45 AM
Guardrail's Avatar
Originally Posted by 98whitelightnin
Pull the stick out.
I've been looking for the dip stick in my 6 speed manual since I bought my truck.
Let me in on the secret place Dodge hid it, would ya?
Old Oct 14, 2008 | 06:56 AM
htgreen3's Avatar
The "stick" was the gear shifter.
I have a hand pump that fits in a lube bottle that I use to pump the fluid back in. Be ready for hand and arm crams.
Old Oct 14, 2008 | 07:53 AM
They hid mine under the number 2 spark plug but its an 03.
Old Oct 14, 2008 | 07:58 AM
Danderson's Avatar
G-56=atf+4.
The G-56's use ATF+4. I refilled w/Amsoil and bought their inexpensive pump. Works great. I always score a big piece of cardboard before changing anything under mine as I always make some kind of mess.
Old Oct 14, 2008 | 08:11 AM
I used royal purple in mine with an extra qt or maybe a little more.
Old Oct 14, 2008 | 08:44 AM
MikeyB's Avatar
I use a 1 gallon gear lube container with a pump for filling the transmission.
MikeyB
Old Oct 14, 2008 | 09:24 AM
CD in NM's Avatar
I use Amsoil ATF, got their pump, works great.
CD
Old Oct 14, 2008 | 09:54 AM
Grit Dog's Avatar
You can get a drill operated pump from Napa for about $10. Then stop at the hardware store for a couple hose bib to hose barb connections and several feet of 3/8" or so hose.
I use that with a cordless drill for anything like fluid into the trans, t case, axles, change oil/trans fluid in the boat, etc.
Old Oct 14, 2008 | 10:50 AM
Roperteacher's Avatar
I use the AMSOIL pump as well!
Old Oct 14, 2008 | 11:42 AM
PRO-NRA's Avatar
X3 on the Amsoil and hand pump. If you come up north on your way to Reno or Tahoe stop by Sacramento and we'll change your G56 & you t-case in my driveway in less than 1 hour. Just buy the beer.
Old Oct 14, 2008 | 10:22 PM
banana's Avatar
Thats what I bought too... Royal...!
