fca
does the truck have a check engine light on? It could be the FCA< but I dont know if thats the most likely culprit. The fact that temperature is changing its behavior is really odd...I might lean towards the rail pressure sensor. I have seen these cause the same symptoms you are describing with no CEL.
just talked to a good diesel shop in des moines(i was told). they think it could be that. they thought it might be something else eletic. would you take it in and let them look at our just replace the fca and try that at home. i found one from cummins...108.00 plus tax.
Its your money.Sounds alot like an fca but with these electronic engines theres alot of possibilities.Ask what they would charge for 1/2 hr with a DRB(or like tool) to check command RP vs actual RP.My local dealer only charged me for the time it took to test(1/2 hr, 1/2 the shop hourly rate).
Just had my FCA replaced under warranty. I dont know if they SHOULD have replaced it under warranty or not, truck has 47k on it. Maybe it is part of the 100k warranty. Anyway, they said it was $217 bucks. Wow. What a rip. Local Cummins store sells it for $103.
Friend of mine had a bad FCA on his truck.He didn't know thats what was wrong.He added a bottle of power service(whole bottle)it cleared up and ran fine.Then no Power Service.Ran poor.Then Howes.Same deal.Then Marvel Mystery oil.Same deal.Then a tech told me STAR(engineering) said to add a fuel lube or 2 stoke ashless oil to diagnosis a bad FCA.Only additive that did not do anything in my friends truck was LUCAS additive.When NOT adding the fuel lube problem would return in the next tank of fuel etc.His truck on cold start ran very uneven and on hot restart would stall at low speeds,chug,surge etc.He thought bad injectors or? It is part of the Engine/fuel system warranty.
just got it back last night from a diesel mechaic. it was not the FCA. This is what he done to it. done all the scans, checked all the flow rates and everything good. lift pump, injector pump and injectors. he found air in the injector return test. he checked the jumper tubes and found the first was a little loose. he then checked them all and all but one was not tight to tourque specs. put them back to the way they are suppose to be and the problem gone. makes since to me . when cold it was not leting air to seep by, as it warmed up it got worse as the meatal expanded. i guess it let just aenough air to seep in to cause all this trouble and to **** me off for a a month or two trying to find this.
Cummins has them for around $100, might be a little more now...(cant find the PN right now
Might also check the relief valve, I *think you just take the banjo bolt out and see if fuel is getting past the valve, might be a bad valve thats bleeding off fuel, and you can just cap it(drill/tap 1/8" npt? I believe)
)Might also check the relief valve, I *think you just take the banjo bolt out and see if fuel is getting past the valve, might be a bad valve thats bleeding off fuel, and you can just cap it(drill/tap 1/8" npt? I believe)
cjones42
Jul 6, 2019 09:49 AM
draskobnsf
17
May 29, 2007 08:29 PM
