fca
Old Feb 19, 2009 | 01:51 PM
mj1044's Avatar
fca
is there anyway to check the fca tha it might be faulty. ohms, continuity or voltage to it?
Old Feb 19, 2009 | 03:03 PM
Erik@LCD's Avatar
measure rail pressure, then unplug the FCA and fire the truck. Should run like crap, only run it long enough to see if its working and hopefully see the rail pressure.
Old Feb 19, 2009 | 03:10 PM
homewrecker's Avatar
Really need to know more of what your problem is.What Erik mentioned doing is gonna ramp the RP to max!Its a good test to make sure its fueling all it can and for checking if your relief valve is blown,but don't let it run for more than a couple seconds or you might end up with a blown relief valve that you didn't already have!
Old Feb 19, 2009 | 03:15 PM
mj1044's Avatar
i did this already. when the truck is run bad...it will not make the rp go to max. after it sets and i do it, it will make it rattle.
Old Feb 19, 2009 | 03:29 PM
Erik@LCD's Avatar
excellent points!what is the truck doing/not doing that you are trying to troubleshoot?
Old Feb 19, 2009 | 03:30 PM
Erik@LCD's Avatar
so what RP are you seeing under normal conditions? Is the truck down on power?
Old Feb 19, 2009 | 03:39 PM
mj1044's Avatar
when the truck is first cranked and i take off, it runs fine untill the temp comes up. then it run like crap. 50 -60 mph is all i am getting and it is hurting getting that. that is turning around 1800-2000rpm. i replased the fuel filter 3 times, the lift pump and the relieve vaule on the rail. still doing the same thing. last week when it warm up in the 50's, it ran half good....cooled back down into the 20's this week...back to running like crap. got to reading about the fca and i thought i would test that. any ideas..do have any way to check the rp. it will die sometimes when it is runnig bad if i caome to a stop and clucth it. The rp is dropping low and killing i tthink. give it 15-20 seconds and it will crank back up. took it in to dodge dealer and they said replace cp3 and lift pump.along with 4k. They figured this out in 30 min. i am looking on my on.
Old Feb 19, 2009 | 03:57 PM
The fca can cause what your describing.There is no real way to test it.Only test is to have the dealer hook the truck to a starscan or drb and monitor actual RP vs command RP.It won't give a difinitive answer but will point you in the right direction.
Old Feb 19, 2009 | 04:07 PM
mj1044's Avatar
thanks for the input. cant i pic one up from a cummins dealer o rdoes it have to come from bosch?
Old Feb 19, 2009 | 04:10 PM
Pooter's Avatar
Cummins has them for around $100, might be a little more now...(cant find the PN right now)
Might also check the relief valve, I *think you just take the banjo bolt out and see if fuel is getting past the valve, might be a bad valve thats bleeding off fuel, and you can just cap it(drill/tap 1/8" npt? I believe)
Old Feb 19, 2009 | 04:16 PM
Erik@LCD's Avatar
does the truck have a check engine light on? It could be the FCA< but I dont know if thats the most likely culprit. The fact that temperature is changing its behavior is really odd...I might lean towards the rail pressure sensor. I have seen these cause the same symptoms you are describing with no CEL.
4932457...pretty sure this is the p/n
mj1044's Avatar
i will see if i can find a dealer here in des moines, ia. i have been here about 4 years and i am not that faimler with the area as far as parts place like this. My older cumminings didnt have any trouble. went to this computer crap truck and it has started. but i am probley get this working right and trade it for a newer one.
Old Feb 19, 2009 | 04:18 PM
Don't buy the fca from the dealer.They will rip you off!Get it direct from Cummins.
Old Feb 19, 2009 | 04:19 PM
mj1044's Avatar
Thanks for all the advice. i will do some checking.
