Fan Fell Off
Old May 11, 2006 | 06:22 PM
lawnman757's Avatar
Fan Fell Off
While driving to my next job yesterday, I lost my power steering and brakes while going around a corner on a busy back road. After getting the truck and trailer stopped safely I got out to find my fan leaning against the radiator (52,000). Had it towed in to the dealer at my cost. Apparently the idler bearing seized up, destroying the hub, serpentine belt, one of the fan fins,crank sensor. Its a shame that was Rokk Tech sensor. Dealer says they will have the truck back together tommorow, but are fighting with Chrysler to pay for all damages minus the $100 deductible. Chrysler only wants to cover the bearing that failed not what it screwed up when it failed. Hopefully the dealer will come through for me. Well hopefully it will be back to new tommorow, as this is the first time the truck left me sitting.
Old May 11, 2006 | 06:24 PM
wcjp's Avatar
Is the idler bearing the same as the second Gen's? I remember the idler bearing in the 2nd Gens had plastic bearing? I know someone made an upgrade of some sort to metal bearings.
Old May 11, 2006 | 09:21 PM
DmaxEter's Avatar
If the bearing was the primary failure, and all that other stuff was the result, then it would all be covered under warranty if it were in my shop. I just did a fan drive hub warranty today where the fan blade hit the radiator and punched a hole in it. The radiator was out of the standard truck waranty, but the failed drive hub was in warranty. Since the hub failed and caused damage to the radiator it was covered under warranty. Contingent Damage I belive its called?
Old May 12, 2006 | 04:23 AM
Dodgezilla's Avatar
That sucks!
So, say the oil pump went out and wiped out all your bearings. Would they try to say they were only going to replace the oil pump?? Sounds crazy to me that they wouldn't want to cover the whole repair less your deductable....
Old May 12, 2006 | 07:35 PM
lawnman757's Avatar
Got the truck back today, minus the $100 deductible. Service manager says he had to fight with Chrysler to cover it though. Only problem is the check engine light came on on the way home and I picked it up at closing. I am going to check the code list to determine what they are and try and clear them with a snap on tool ( service department not open till Monday).
Old May 12, 2006 | 07:59 PM
handymantim's Avatar
That manager is such a nice guy.....right! Glad you got your truck fixed.
joshuabuilt
Jul 30, 2015 06:29 PM
big jimmy
Jul 7, 2006 01:33 PM
97Dually
Nov 20, 2003 01:22 PM
RamDan03
Nov 9, 2003 10:26 AM
1320
Aug 30, 2003 10:10 AM
