Factory Limited Slip
Old Apr 5, 2009 | 01:28 PM
nkh95's Avatar
Factory Limited Slip Repairable?
Hey guys, I 'had' functional factory limited slip until recently. Changed gear lube and it came back to life briefly. What wears out? How do I fix it?
Early 2003 2500 5.9l cummins with 6 speed manual. Thanks,
Nick
Old Apr 6, 2009 | 07:08 AM
Peterbilt's Avatar
Did you overfill it? Also, Dodge now recommends using a friction modifier.
Pete
Old Apr 6, 2009 | 07:40 AM
mikmaze's Avatar
the limited slip needs resistance to function, if off road, a touch of brake peddle or a touch of e brake will help it sense load, and lock.
Old Apr 6, 2009 | 01:27 PM
Billy Ram's Avatar
The TracRite helical LS doesn't like oil that has friction modifiers. The slipperier the oil the less the TracRite locks. These differentials don't lock up like the Dana does with clutch plates. Fill it with cheap 80-90w GL-5 and change it often.
Billy
sqrl$$
16
Jan 6, 2007 05:28 PM
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
NWDave
Jan 25, 2003 06:03 AM
Srigs
Nov 13, 2002 09:30 PM
