factory exhaust brake
Old Jan 13, 2008 | 09:07 PM
snoyes's Avatar
I agree,
Really like has been said, only guys with the problems tend to check in. If you got it, use it. It really made my last trip from Alaska down to Illinois enjoyable. Nothing like having control over your trailer heading down 9% grades. That "pucker" factor was gone.
Old Jan 20, 2008 | 07:53 PM
Tree DR's Avatar
You guys that mentioned problems what was the problem and what was the damage?
Where does the wireing tap into the TPS? Also when the clutch is in the brake should shut off?
Old Jan 20, 2008 | 09:40 PM
Utundra's Avatar
I paid just under $1000 for the Jacobs brake and installed it myself. This was less expensive than any BD or Pac brake pricing I could find. While there might be concerns with the vacuum pump failing, a replacement is just over $100.
My seat of the pants tells me the Pac brake has more braking than the Jacobs-Mopar/Cummins, but I am pleased so far with my Jacobs.
Good Luck...
Old Jan 20, 2008 | 09:51 PM
ERK1974's Avatar
What About Us Gear Brake. Its Away From The Turbo Which I Like. It Has A Gate Valve In It To Keep The Proper Pressue Going. Does Anyone Have This Installed.
Old Jan 20, 2008 | 10:36 PM
dadwolf2's Avatar
The Cummins engineer's designed the engine to have an exhaust brake right outside the turbo. That's why the removable elbow is there. Also believe there is more engine exhaust braking at that location too.
I installed my PacBrake PRXB EB two years ago and really enjoy it. Haven't had any problems. I think the key too any EB not sticking is to use it. I leave mine turned on 99.9% of the time. I only lube it 1-2 times a year.
NO_SPRK
Dec 21, 2008 03:00 PM
Mopar72
Dec 9, 2008 10:14 PM
jthorpe
Aug 28, 2008 07:37 PM
f272272
Dec 28, 2007 01:55 PM
ramhardv8
Jun 2, 2006 11:22 PM
