Exhaust Manifold Question
Old Dec 28, 2008 | 07:38 AM
D45's Avatar
D45
I have a 2pc ATS manifold, that I am trying to take apart (and eventually put back together).
When I put it back together, I need to have the bolt spacing correct.
Can anyone either measure their exhaust manifold, so I know what the bolt spacing.....from the center of the one (firewall end) mounting hole to the center of the other (radiator end), for both the top and bottom holes?
Hope that makes sense..........
THANKS!
Old Dec 28, 2008 | 12:34 PM
Toolman 9304's Avatar
The bolt spacing is 4.725 on the head
Old Dec 28, 2008 | 01:38 PM
D45's Avatar
D45
So this is from the center of one head to the center of another head, all bolts have the same spacing?
THANKS!
Old Dec 28, 2008 | 04:08 PM
D45's Avatar
D45
Also, are new bolts/studs needs to install aftermarket manifolds or are the stock bolts re-used?
Are the stock bolts safe to re-use without worrying about snapping them?
THANKS!
Old Dec 28, 2008 | 06:00 PM
bob4x4's Avatar
The stock bolts are fine on the 3rd gens with the ATS
Old Dec 29, 2008 | 09:23 AM
D45's Avatar
D45
Thanks for all the info guys!
Next question, after I reinstall the two halves and get the proper spacing, do I just need to put a straight edge on the mounting flanges to make sure it is 110% completely flat?
silkywoods
35
Feb 6, 2008 12:40 PM
cwoodall
Jan 10, 2008 11:31 AM
drewblood
Aug 19, 2007 02:27 AM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
