exhaust brake
Old Dec 11, 2014 | 10:42 AM
Haro ld's Avatar
exhaust brake
does a exhaust brake damage a48re transmission
Old Dec 11, 2014 | 03:28 PM
NJMurvin's Avatar
I don't have first hand experience but I researched exhaust brakes for my 2004.5 a long time ago. Starting with the 2006 models they offered a factory or dealer installed option for an ebrake. Supposedly, there is a thrust washer on earlier model years that is prone to damage. Also, I believe there are electronic enhancements in 2006+ models to support an ebrake that don't exist in the earlier model years. But, I believe the 3rd party mfrs provide something to handle that in pre-2006 trucks. It has been awhile and things may have changed, so I recommend you continue doing your research.
Old Dec 12, 2014 | 12:21 PM
Haro ld's Avatar
thanks for the reply It sounds like it will be ok we have a 32 ft 5th wheel didn't know if its clutchs would stand the positive push
Old Dec 12, 2014 | 01:12 PM
NJMurvin's Avatar
It would help if you put your truck info in your signature. Assuming you have a 2006 or later, then you are probably fine. If not, find out if your thrust washer might be at risk.
rcs7
Sep 30, 2009 12:05 PM
Mopar440_6
Feb 11, 2007 10:50 PM
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
