Error Code 0111
Error Code 0111
Hello. When I hopped in my truck the other day the CEL came on. Pulling the codes showed 0111. Using the great search function of this site I see this is related to:
Intake Air / Charge Temperature Sensor Performance / Rationality
Does anybody have an idea what could have caused this problem to show up. I replaced the air filter the day before when I changed the oil, so I may have knocked something loose. The truck is a completely stock 2006 dodge with 16K miles
WAP
WAP
WAP
WAP
Derek
when the weather gets cold, sometimes there are erroneous codes generated. usually the air temp rationalitly and battery temp codes. nothing to worry about, the ecm just gets confused. it will clear itself after a few full warm up/cool down cycles.
Dodge has a TSB on this and other codes. http://dodgeram.info/tsb/2006/18-005-06b.htm This TSB applies to the 2006 model year. I had my truck flashed and have had no further problems.
DodgemnLeavem
Jan 24, 2010 11:17 AM
JaredOlsen
Mar 16, 2007 10:56 AM
