Engine Shut Down Chirp
Old Oct 28, 2004 | 07:15 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Why is it that some 3rd gens have the chirp and some don't? My truck has never done it but in the past few days I've personally witnessed three different ones that did.
Old Oct 28, 2004 | 07:47 AM
BB6Wheeler's Avatar
Hoss,
Mine "Chirps" at least 95% of the time Hope this is normal.
Old Oct 28, 2004 | 08:15 AM
jbrown2861's Avatar
MY buddy has a auto and his chirps every time he shuts down. I have the 6 sp manual and it never chirps.
Old Oct 28, 2004 | 08:40 AM
HdPower's Avatar
Mine "chirps" maybe 85 % of the time...the other 15 % it kinda makes a Prissssssssssh....clank noise when shutting down, not quite sure what that is.
Old Oct 28, 2004 | 08:42 AM
Pointing Labs's Avatar
It is in the manual, It will do it a lot of the time.....and it is normal
Old Oct 28, 2004 | 02:37 PM
Hoss's Avatar
I understand that it's normal, but why do some trucks do it and others don't? Mine has NEVER done it....but lately I've seen several others that have.
Hmmmm.....I wouldn't think the transmission would have anything to do with it but maybe that's the key??
Old Oct 28, 2004 | 03:22 PM
Peterbilt's Avatar
My chirps. The better it's running the louder it chirps. It's music to my ears
I belive the gatorback belts eliminate it.
Pete
Old Oct 28, 2004 | 04:04 PM
I am pretty sure it is because we have automatics and you don't....I will check in the book because it says what it is but I haven't had the chance to look it up..
Old Oct 28, 2004 | 04:50 PM
The big heavy clutch and flywheel on a manual make the crank stop more gently than the lighter flexplate and torque converter on the automatic.
Old Oct 29, 2004 | 06:50 AM
Hoss's Avatar
So now we know.....I guess.
Old Oct 29, 2004 | 09:39 AM
Tmc243's Avatar
When you shut down our engines there is so much compression, that the crank pulley stops turning before the rest of the pulleys, (kind of like locking up your brakes and the tires skidding) causing the serpentine belt to slip on the pulleys and make a chirp noise.
Old Oct 31, 2004 | 07:08 AM
MOPE540's Avatar
thanks for the explanation... I had no idea what caused the chirp, and passengers often ask "what was that?"..now I know what to tell 'em
my automatic does it maybe 60% of the time.
Old Oct 31, 2004 | 08:17 AM
mikmaze's Avatar
if ya want it to stop a little wd40 will halt that noise
Old Oct 31, 2004 | 11:05 AM
t-15 firefighter's Avatar
DTR's Self Appointed Beer Advisor
mine does it like a madman!!
almost EVERY time i stop the engine. i really thought something was wrong with it. glad i belong to a place that you can get some good quality information
my 03 was a 6 speed and never did it but this one is an auto so that must be the cause.
britt
Old Nov 1, 2004 | 01:58 AM
SuperGewl's Avatar
You may NOT want to use anything like that on there. It can lead to other problems such as the belt slipping off, or causing the belt to deteriorate. Just my penny worth of advise.
