engine run-away,HELP!!
Old Jun 5, 2009 | 11:02 PM
#2 only's Avatar
Originally Posted by 03 ant a hemi
It could have shorted out that injector, but more then likely it caused the ECM to go into limp mode.
If you have not done so yet, disconnect the batteries and leave the key on for a an hour or so.
Turn the key off and reconnect them. See if that helps.
You may also have a bad injection pump.
Is your friend experancing hard starts?
No hard starts,replaced sticks,but no limp mode either.I'm thinking maybe fried injector driver in ECM.
It only occurs when you get the revs high, but not when you disconnect the 1st injector harness connector.
Old Jun 5, 2009 | 11:28 PM
RCW's Avatar
RCW
Once you have had bare wires making contact with a ground you run the risk of program failure in either the fuel pod control on top of the engine, or in the PCM and or ECM.
This is the sort of failure that will require a competent dealer to perform a scan, and once the companion codes are analyzed the fix may be as simple as a Chrysler reflash.
Whatever you do, do not swap ECM's from a good truck, that may just lead to trouble for the donor vehicle.
Old Jun 5, 2009 | 11:31 PM
cody459's Avatar
Almost forgot something if you replaced all the injectors by now and its still holding its rpms in park, have you checked the limit valve.
Old Jun 5, 2009 | 11:57 PM
03 ant a hemi's Avatar
a trip to the dealer for a scan of the system is in order.
Old Jun 6, 2009 | 04:38 AM
#2 only's Avatar
Yes, it's been replaced as well.
Old Jun 6, 2009 | 04:40 AM
#2 only's Avatar
Ok, that's what I thought would be good even though we'd all like to avoid it.
THANKS to you all for helping out.
Old Jun 6, 2009 | 06:13 AM
mikmaze's Avatar
good luck an d let us know what it was when they get er fixed.
Old Jun 6, 2009 | 07:56 AM
#2 only's Avatar
[QUOTE=mikmaze;2497898]good luck and let us know what it was when they get er fixed.
10-4 !
hotmod660
25
Feb 3, 2014 06:02 PM
beegiedog
27
May 4, 2011 08:55 PM
yarddog
Oct 26, 2005 06:50 AM
tool
15
Jan 23, 2005 03:25 PM
