engine problem
engine problem
I just had a new problem come up on my truck it will be running just fine I can shut it off come back it will sound like its running on two Cylinders shut it off let it sit for a minuite or so restart it and its fine no codes .
It also dosent have any low end power its fine above 2200 rpm .
The dealer said I had to much ilde time. D&R Garage siad it was the ceps pump ?
any help would be appericated
From what you stated it could be a pump issue or injectors, but you also might want to check the harnesses on the valve cover gasket and make sure everthing is working right there, if you have a short there or loose connections it could cause the issue.
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
dogman
Dec 27, 2003 07:06 PM
