engine died
Old Jul 30, 2007 | 09:00 PM
khalgren's Avatar
engine died
Today while driving about 35mph the engine just quit. I pulled to the side of the road and after several trys the engine started and ran normal. I made a stop and had a devil of a time getting it started again, it would start and die. After it finally started I drove home at normal speeds and it ran fine. Checked the code and it is P0628. I read some posts on that code and most said it was the lift pump. If is is the lift pump why would it finally start and run normal? Thanks for any suggestions.
Old Jul 30, 2007 | 09:43 PM
TonyB's Avatar
Fill out your signature...year, model, options, etc. so we know how to best help you!
Tony
Old Jul 30, 2007 | 09:45 PM
vzdude's Avatar
DTR's 'Go to Guy'
Sometimes the lift pump will get hot and seize. Cools down a little and it will run again. For how long? No one really knows, but I would make plans for a new one quick!
Old Jul 30, 2007 | 10:18 PM
khalgren's Avatar
Ok, I think I have my profile updated. Thanks for your replys.
Old Jul 30, 2007 | 10:24 PM
khalgren's Avatar
Well, that didn't work.
I have early 2004 4wd 2500, with a Edge/Attitude and Scotty III air cleaner.
I haven't tried removing the Edge yet, could that be the problem?
Old Jul 30, 2007 | 10:35 PM
vzdude's Avatar
DTR's 'Go to Guy'
Could be, but doubtful with the lift pump code. Edge doesn't affect that at all I'm pretty sure.
Old Jul 30, 2007 | 10:57 PM
Smithereen's Avatar
My truck ran for a while with the lift pump dead. If the pump quits in the right position fuel will still pulll through it.
NickBeek
May 2, 2008 08:41 PM
Rob1325
Nov 19, 2005 06:25 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
Mark Hodowanec
Jan 17, 2005 09:15 PM
JerryB4
Oct 9, 2003 10:09 PM
