Engine Clatter
Old Sep 29, 2011 | 06:42 AM
Hintonc393's Avatar
So I guess we have decided that it is pre ignition. Pre ignition is bad for a engine and will cause problems like burned valves and burned pistons if it is not fixed. Not to mention it is bad for fuel economy. So what do you do to fix it? Do any of the programmers remove timing? Do any dealer updates remove timing? Do you set the valves looser?
Old Sep 29, 2011 | 07:18 AM
AH64ID's Avatar
It's not a damaging issue like it is on a gasser.
Old Sep 29, 2011 | 11:49 AM
NJMurvin's Avatar
I have been seeing this with my truck for awhile now. I'm glad to hear it's something fairly common. One thing I've observed is that it's much more noticeable when the AC is on. Is that because of the load of the compressor, open vents allowing more engine sounds in? Or, am I just imagining things?
Old Sep 29, 2011 | 03:53 PM
Hintonc393's Avatar
Gas engines are built from the same things a diesels, why would it burn a valve in a gas engine and not a diesel.
Old Sep 29, 2011 | 04:45 PM
AH64ID's Avatar
Because it's not really doing the same thing. It's not detonation in a diesel. Diesel is supposed to ignite as soon as it enters the cylinder, gas is not.
Timing rattle happens on most diesels, its just easier to hear on HPCR's because the pilot injection makes the main combustion quieter so you hear things besides the combustion.
buddiesel
26
Apr 30, 2006 08:19 AM
paulthor
13
Apr 17, 2006 08:19 AM
Arlon
Oct 26, 2005 07:27 AM
shemp47
75
Jan 13, 2005 01:21 PM
My 03 HO
14
Jun 19, 2003 06:02 AM
