Electric TV Motor Question
Old Mar 23, 2009 | 08:01 PM
HIGHGEAR's Avatar
What are the signs that the TV motor is bad or is starting to go bad?
Old Mar 24, 2009 | 08:05 AM
HIGHGEAR's Avatar
Anybody have any ideas
Old Mar 24, 2009 | 10:08 AM
paulb's Avatar
The symptoms vary widely. The reason is that they can stick in any position. If it sticks open (fully turned), then you will get hard shifts, shifts at higher rpm, etc. If it sticks closed, then you will get quick shifts at lower rpm, even at WOT. You can also get increased wear because of lower line pressure. As always putting a pressure gauge and measuring line pressure, is the best way to check it.
They do fail fairly often too. Specially in wetter climates.
Paul
Old Mar 24, 2009 | 06:50 PM
HIGHGEAR's Avatar
Hey thanks Paul.
Diesel Girl
18
Oct 6, 2013 03:03 PM
cj5er
Dec 20, 2009 09:19 PM
Common
May 9, 2007 12:11 AM
4x4dually
Jan 5, 2007 03:15 AM
Marine
Oct 22, 2005 11:43 AM
