EGT's
Old Dec 7, 2009 | 02:30 PM
Mark_07's Avatar
EGT's
I have a 04 Dodge dully Cummins with a 6-speed manual trans, and I haul a 18k lb fifth wheel trailer with it. I have a guage for the EGT's, but I'd like to know what are the maximum recommended temperatures I should ever see on my guage when hauling? (What is the maximum temperature for consistant driving?; what is the maximum temperature for a temporary period of time?) Thanks.
Old Dec 7, 2009 | 08:02 PM
matt69olds's Avatar
I have a friend who was a engineer at the Cummins engine plant. He told me the engine is rated for 1350* at max engine speed for 10000 hrs. It will handle higher temps for a short period of time. So I guess to answer your question, the max "safe" temp would be 1350* all day.
Old Dec 7, 2009 | 10:39 PM
Brad5502's Avatar
I''m much more conservative than that!
Good post on towing forum on EGTs below.
https://www.dieseltruckresource.com/...g-t255404.html
I down shift to keep my pre-turbo EGTs around 1100-1150. With my 5 speed and 13.5K 5er in 100 degree temps, I usually cruise up the grapvine in SOCAL (long 6% grade) in 3rd at 35-40MPH, EGTs around 1000 and I think RPM around 2300. In 4th RPMs drop below 2000 and EGTs quickly go over 1200 as the engine starts lugging.
BTW I use the Smarty standard 5 setting with my SO...seems best setting to keep EGTs down.
Old Dec 8, 2009 | 12:03 PM
AH64ID's Avatar
Early 04 or late 04?
03-04 should be in the realm of 1250* max continuous.
04.5-07 should be 1375* max continuous, and up to 1450* for short spurts (like hills and such).. In fact some sources say 1450* is max continuous stock.
Old Dec 8, 2009 | 10:02 PM
Mark_07's Avatar
My truck is a Late '04' model.
Old Dec 9, 2009 | 09:55 AM
AH64ID's Avatar
Stock fueling should be fine, regardless... should...
You can do things like improve intake/exhaust flow (wont net you any power, but may drop the EGT's a few *).. I like the Airaid MIT (keeps the best parts of the stock system and replaces the worst), and a cat delete...
If you want a little oomph and lower EGTs the Smarty Jr is the way to go.
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
